After reading a few threads, this was my approach to stop this gasket from leaking:
1. Cleaned the block mating surface until it shined! No residue from previous gasket.
2. Used permatex high tack gasket sealer on the housing surface (used a new thermostat housing), placed the gasket on the housing, then painted a coat of gasket sealer on the opposite side of the gasket and mounted it to the vehicle
3. Painted a coat of the gasket seal on the threads of the bolts, let it sit for a minute before installing them
4. Torqued the bolts to 20ft/lbs and let it sit for 24 hrs before starting the vehicle or adding more fluid.
All surface were completely dry and clean before installing.
What else could be the problem. The leak is a lot smaller now, only a drop a minute, but it still leaks. Is there a specific way to seal the bolts? Would new bolts help? The old bolts looked pretty run down. And the latest leaking gasket appeared most worn down at the area of the bottom bolt hole
