Drooped the Jeep off for a regear. Yay stimulus. I hate spending the money but I also hate not using the interstate. No pics.
purchased off amazonDid you make the truss?
I hit it with a wire wheel, then used degreaser and a nylon brush to it all. i used simple green and also greased lightning. Then used rust converter primer, then paint!What did you do to prep for the painting. I recently bought a Dana 44 that I will eventually install in my TJ replacing the Dana 35. I was thinking of once I have it all stripped down I would take it to a local shop and have it sand blasted. Once it is nice and clean I would paint it. Did you clean/degrease the axle yourself? If so what did you use?
Ya need to post some pics.Primed the hood getting it ready for paint. Clear coat was bad. Had six layers so took it down to bare metal.
And now you have matching purple saw horses.
She found some mud. I learned a couple things: roll up the windows(although the window stays clean that way ) and don’t forget to engage 4wd. LolView attachment 152021View attachment 152018
I've heard those have infinite amount of flex, but you have to stay in range and keep them updated...Installed my new Bluetooth axleView attachment 153284
Did you use rattle can spray? Looks great!Sanded and repainted my door to remove a scratch, then installed a bazooka sub!
