So this afternoon I changed out my rear brake line for an extended line. The section on the frame went well, still had a few bumps to get over but made it without too much trouble. but the axle part was some what of a problem (for the Dana 35) because once I tied the two lined into the junction connector, getting the vent bolt in for the axle would NOT go in because it just would not line up because the line coming from the passenger side is so close to the chunk. it took quiet a bit of pushing and bending to get it connected, and that was after i turned over the brake fluid i caught while disconnecting the lines and brake fluid running everywhere over me. but alls well that ends well , right? i bled the rear brake lines and no leaks. so im good.
