So I’ve been looking into winches. Does anyone here have experience with the warn vr evo? The price isn’t bad and I’d like to get some input on it before pulling the trigger.
You'd honestly be better off saving up a bit more and getting something better than a VR series winch. A good used M8000 would be cheaper, and a better winch. Or a used M8274, but you'd need a special winch plate for it. I'd even pick a Superwinch LP8500 over the VR8.
Superwinch LP8500. It was definitely warm, but it did not overheat after all that winching.
To the OP--Its a very affordable winch. Last I looked it could be had for about $300 (maybe less) direct from Superwinch. Its a slow winch, but it works. It also inlcudes some sort of circuit breaker which are three, 50 amp breakers mounted on two bus bars that connects direct to the pos. battery post. The clutch is also finicky, but that may solved with greasing the clutch on mine.
I just ordered a Warn M8000 today. I guess I bought into the forum hype. I try not to do that to simply follow the crowd, but try as I may I could not find anyone to say a bad thing about them. Reviews, warranty services, parts availability, classic design; all point toward it being a good decision.
