Currie knows somethingThis JKS is BS. I have to shorten my lowers all the way on the drivers side to clear. WTH?!
passenger side clears fine at full bump
Nothing a good chop saw can't fix.I believe his lowers are as short as they can go. He’s not trying to push his axle back he’s trying to rotate his pinion for a tummy tuck
I've got competition!He's going to be a trail hero.
It is interesting to see which companies build their stuff to wheel, and wheel hard.Sometimes I wonder if the idiots who build this stuff ever worked on a rig. I’m sure @mrblaine could have words
To be fair, lots of places got a set of parts figured out that worked and worked well. Then we come along and start tweaking, poking, prodding, nip here, tuck there, move some shocks around and before long, all the little things have finally added up to where the old standard isn't as effective as it used to be.Sometimes I wonder if the idiots who build this stuff ever worked on a rig. I’m sure @mrblaine could have words
Currie did just that on the old JKS stuff.It is interesting to see which companies build their stuff to wheel, and wheel hard.
Do you think the rise and fall of RE was along the same lines? Or was that attributed to marketing hype.To be fair, lots of places got a set of parts figured out that worked and worked well. Then we come along and start tweaking, poking, prodding, nip here, tuck there, move some shocks around and before long, all the little things have finally added up to where the old standard isn't as effective as it used to be.
All you need to do is work on these things to know. ShitIt is interesting to see which companies build their stuff to wheel, and wheel hard.
No idea.Do you think the rise and fall of RE was along the same lines? Or was that attributed to marketing hype.
You mean the parts worked well together. I guess I get that.To be fair, lots of places got a set of parts figured out that worked and worked well. Then we come along and start tweaking, poking, prodding, nip here, tuck there, move some shocks around and before long, all the little things have finally added up to where the old standard isn't as effective as it used to be.
The integrity of the parts we can bolt on today to produce a well handling, well steering, well stopping rig is just pretty darn high.That, and the limits of the platform got pushed further and further over time. Not everyone kept up with what is possible.
wait till the lockdown is over and take it to a press
@Chris ring any bells?
What is the minimum distance C to C of the lowers?This JKS is BS. I have to shorten my lowers all the way on the drivers side to clear. WTH?!
