The LED indicators in the switches - even the stock one - could be a bit brighter, but they'll do and they work well.
I need my wife or someone to help me with the steering test. I think that's the only way I can fully diagnose the boat like ride. It really feels like when you are in a small boat with waves. It goes up and down and then side to side a little. It doesn't pull, but you have to be on it to keep it steady.
Reactions: Blondie70
OEM pitman arm?
I do not know why my pictures are sideways. I apologize for that.
Last time this pitman arm thing came up, I think someone said mine is dropped but it is okay because there is a bracket for it to be dropped?
Reactions: Fonz54
For $50 I'd try the OEM part. Can the drop bracket easily be removed?
Looks fairly easy to remove. If it was me I'd replace it. Worse case it doesn't fix anything but the jeep will be properly set up.
So this was an additional part, not a replacement part? Remove both pieces and I should be good to go?
More googling indicates in may be my tire pressure. I checked and mine were at ~32. I looked around and it appears the suggested PSI is ~26 for 35x12.5R15 tires.
