Installed TeraFlex 2" budget boost coil spacers.
I can actually slide under the jeep now and inspect stuff which is nice.
Installed a BBK 1724 62mm Throttle Body that someone sent me for my birthday.
It fixed an annoying slow idle problem that just wouldn't go away no matter what I did.
It was sometimes accompanied by a stall and IAC fault code. All sensors are MOPAR.
Had the old throttle body off twice cleaning it thoroughly, but problem remained.
I will say that it runs incredibly smooth with the new T.B., and starts faster when cold and hot.
While changing the Throttle Body, noticed hairline cracks in #2 & #3 injectors. They weren't leaking, but I didn't like the idea of leaving them alone, so replaced all the injectors.
Last weekend had a local shop install TrueTracs front and rear, left the stock gears alone, 3.73's.
Now that the TJ is running sweet, I'm expecting the head to crack, as that's just how my luck usually pans out.
