I've been running a 2.5" lift on stock control arms for over a year now; I assume the control arms are original. The bushings are clearly shot by now: they are all cracked, I get some weird pops when the weight of the jeep shifts from accelerating, etc. It's time for new control arms. Due to being a college student with no money, and being completely out of work from ~Covid-19~ I really didn't have the money for a nice set of Savvy double adjustables like I'd love to have. I don't wheel all that much so I have been eyeing the Core Tier 2 arms for a while, but at $800-$900 they are still out of my price range.
A month or so ago I found full a set of Rough Country arms on FB Marketplace for $50 and decided I could probably restore them to be about as good as the Tier 2 arms. Here is what they looked like when I picked them up
I have since completely pulled all of the dog shit X-flex joints out and knocked all of the rubber bushings out of the ends. I essentially plan to reuse the tubing from the arms but make them far better quality, but I wanted some eyes on my plan before I order everything.
For the flex joints, I plan to replace those with Johnny Joints. I considered DDBs, but having seen some question as to the durability and longevity, I just don't have the money, time, or desire to find out how well they hold up. I have not verified the thread sizes yet, but after some research I believe the lowers are 1-1/4" and the uppers are 3/4". I believe the JJs I need are the CE-9114 for the lowers (x4) and the CE-9112N75-12 (I think?) for the uppers (x2). I will do the front upper JJ kit eventually but for now I'll leave the stock bushings. A couple questions regarding the JJ ends: can I reuse the stock hardware (bolts, flag nuts, etc) or do I need to get the JJs that come with the greasable bolts? Also Im assuming to only use the RJ/Currie grease with the JJs?
For the bushing end, I think I will end up having to use poly ends. I have looked and cannot find any companies that offer flanged split rubber bushings in the wide range of sizes that companies like Prothane and Energy offer poly bushings in. The ones I removed from the RC arms seem to be rubber and have part numbers printed on them, but I found nothing when I tried to look them up. The lower bushing has a 1.5" OD (not the flange side) and 1/2 is 1" long. I should be able to replace them with these from Prothane. For the upper bushing end, I'm struggling to find anything complete, the bushing itself has a 1.5" OD as well but it 7/8" long. It has MO2437 printed on it, and if I looked that up, I get linked to these poly bushings from Skyjacker. I would rather use better quality but it seems they might be my only option. They don't even come with a sleeve, so I will likely have to buy some 3/4" OD, .5" ID steel sleeve and cut to the length I need.
One thing I wasnt sure of was if I could just buy 1" long bushings and shave them down to 7/8" potentially? I couldn't find much info about this on the Internet.
My biggest question regarding the arms is if I am screwing myself by using a JJ with a poly end. I know the Tier 2 Core arms are recommended for those that don't wheel too much or too seriously, and I think that would be fine for me. I am perfectly acceptable knowing my setup may not articulate as well as a double-JJ arm would, but I don't want to waste my money on JJs for these RC arms if the poly end is going to ruin them or limit all of the flex.
Oh and to compare costs--
Core 4x4 Tier 2 arms with no hardware: $820
Frankenstein setup: $480
Arms- $50
JJs- 6 @ $60 - $360
Poly bushings- 6 @ ~$8 a piece- ~$50
Jam Nuts- Reuse from RC
Clean & Paint- ~$20
I'm really hoping for feedback, advices, and critiques before I drop some coin so please let me know what you think!
Arms- $50
JJs- 6 @ $60 - $360
Clean & Paint- ~$20
