Adams Drive Shaft Length Question
Missouri99TJ
Missouri
Long story short..
Had a noise.. pinpointed it the U join in the rear of the front driveshaft where it meets the transfer case.
Going to use this as an opportunity to order a new Adams driveshaft.
Jeep has 4 inches of lift.
When I use the current measurement instructions to measure yoke to yoke I come up with 39.5". (See pics below).
Is this the same adams front driveshaft I want to order?
I assume it will have needed play 2 inches either way?
Thank you for guidance.
That's the correct measurement to use. Just make sure to request they use Spicer 5-1310x u-joints, not a house brand. Even when I order from my favorite DS manufacturer www.4xshaft.com I request they use Spicer instead of their house brand u-joints.
Thank you for the feedback.
Ordered the extreme heavy duty one:
"Hearty Construction. As part of the Extreme Duty Series, this Adams Driveshaft Kit is made to battle even the roughest of environments. The front driveshaft features a 1310 CV Shaft with a beefy 2 inch x 0.120 thick wall and strong Spicer Solid 1310 U-joints. The kit even includes the necessary Grade 10 CV bolts, which have small heads for a simpler installation."
Make sure they're not the greasable Spicer 5-153x which is not as strong or as durable as the sealed 5-1310x.
I believe they are the solid ones cause I got the extreme heavy duty. The regular heavy duty had greasable.
These are for use up-to 37" tires.
Tho I run 35s. But wanted the extra heavy duty one. Might as well right.
I would verify the exact model number they use with them first. Descriptions can imply lots of things that are not completely accurate.
