Hey all, I’m trying to future-proof some upgrades on my ’05 TJ and could use some thoughts.
Current setup:
Current Project:
I’m swapping out the leaking NP231 for an NP241 and finishing a tummy tuck, raising the transfer case ~3”. This changes driveline geometry:
Saving up for JK-width axles from Currie:
Appreciate any insight or real-world experience. Thanks!
Current setup:
- 2005 TJ
- 4” Savvy lift on 35s
- Rear: Super Dana 35 w/ chromoly shafts
- Front: Dana 30 w/ chromoly shafts
- Driveshafts: Adams 1310 double cardan front and rear
Current Project:
- Rear: New t-case flange + 1330 yoke, plus about 2” added length
- Front: Yoke is different, and length is up about 2” as well
- Rear: Currie 60 JK Hybrid High Pinion
- Front: Currie 44 JK Hybrid High Pinion
These usually come with 1350 yokes (or I can spec them that way).
- Rear: 1350 double cardan shaft with flange + 1350 U-joint. Use a 1350 x 1310 conversion joint to run with my Dana 35 until the axle upgrade.
- Front: 1350 double cardan shaft, swap in 1350 yoke at the t-case. Use a 1350 x 1310 conversion joint to run with the Dana 30.
- When ordering the shafts, what length should I use?
- Rear flange-to-yoke is currently 17 7/8"
- Front flange-to-yoke is currently 41"
Should I order based on these, or adjust for the future axle swap?
- I assumed the Currie HP axles (with larger center sections) would result in slightly shorter driveshaft lengths, but I’m finding mixed info. Has anyone run into this?
- I reached out to Adams for input and got the usual “measure when you install” response—which isn’t super helpful when trying to plan ahead.
