Sometimes I get reminded about how I flushed my rigs in the past. It was from the city tap water with a garden hose![]()
if our water wasn’t so hard, I’d consider it. It was truly a tedious process that took way too long.
I've heard (actually, just heard this recently) that, if you put too much tape on, it can actually cause it to peel back as you screw the plug/pipe/whatever in and it "bunches up" outside the mating threads rather than following them in and sealing the gaps. Maybe just something to keep in mind.Drain plug on the Teraflex diff cover (front) was seeping oil despite having used teflon tape. So I drained the oil, put MORE teflon tape on the plug, reassembled and re-filled. Hopefully it was enough...
I got that "this time" as well - dunno how much got left behind. The darn drain plug isn't a taper fit, and feels pretty loose besides - I've never encountered a drain plug that wouldn't tighten up, but this one only gets tight when it bottoms out. If it doesn't work this time, I'm gonna use Permatex on it I think.I've heard (actually, just heard this recently) that, if you put too much tape on, it can actually cause it to peel back as you screw the plug/pipe/whatever in and it "bunches up" outside the mating threads rather than following them in and sealing the gaps. Maybe just something to keep in mind.
Try two years, that's how long I looked for the LJR. I did have a pretty sweet TJ during that time so I could be picky.BTW....finding a great condition LJ these past few weeks has NOT been an easy task.
Actually, I was thinking of just the good old classic "Form a Gasket". That stuff has gotten me out of more problems than I can remember! Even used it on a polyetheline pipe barb fitting once that just would NOT stop leaking - its probably still there to this day!If you're talking about Permatex High Temp Thread Sealant, I used it on the threads of the coolant temps sensor, the metal pipe coming off the water pump and the block drain plug when I serviced my cooling system back in Nov of last year. I like that stuff. I don't know how it would work with gear oil though. It might say on the back of the package.
I think HAL's having a breakdownI'm about to order a bunch of parts in preparation for vacation in a couple weeks. Jeep almost didn't make it to work the other day. P0352 and p1391 have now been added to the already long list of trouble codes. I have another engine harness that I am going to check out and put on. Timing set, rear main, probably intake gasket too. But for right now, it's not drivable. Sputtering, missing, coughing, won't rev up.
Good dog.Installed a new soft top, Bestop Supertop NX in Spice. Seems pretty good so far, got it from Amazon with the full hardware kit since my TJ came with a hardtop only. The dog helped.
View attachment 183265View attachment 183266
Man how do you get your top down into the tub like that. Mine always sticks up a tad.It rained all last night and my Jeep got rained in, so the back was soaked.
But a little sunshine with the top down fixed that right up.
Here! It’s so easy to do once you get the hang of where everything is supposed to tuck inMan how do you get your top down into the tub like that. Mine always sticks up a tad.
We get like 98"/ year and it's rained hard every day for three months!Put the hard top back on. We have had more rain in our area this year than the past 5 or 6. Normally August is pretty dry here.
Well now you have a unicorn so hold onto it lol I bet it was worth the wait.Try two years, that's how long I looked for the LJR. I did have a pretty sweet TJ during that time so I could be picky.
