31 or 33" Tires?
fourmustangs
Houston, TX, United States
31 or 33" Tires?
so needing to replace tires, currently have 31" so trying to decide to stay 31x10.5 or go to 33"
If I go to 33" do i stay with 10.5 or do 12.5 on the width?
my wheels are 15x8
What gears do you have? What type of offroading do you do, and if it is moderate what rear axle do you have? Do you have the clearance for 33s (lift, etc.)?
First jeep,
plan to go to couple offroad parks nothing serious (play in dirt, etc..lol)
I have 3.73 with Dana 30/35
Currently have 3.5" (its a crappy setup but will change it out)
Without seeing a photo, I'd imagine a 3.5" lift would look a little odd with 31's.
Considering you already have a lift and you're gearing is 3.73, I would go to 33's. But you failed to mention if it's an auto or 5 speed manual. Lets us know.
Cheers!
Doesn't it rain heavily in Houston at times? If you have to drive your Jeep on really wet roads much, the 33x12.50 tires will hydroplane a lot more easily and at slower speeds than would happen with 33x10.50 tires. Think using water skis vs. snow skis on water.
Offroad, the 33x10.50 works well in most conditions. The 33x12.50 is the more common choice but don't be afraid to go with the 33x10.50 if you have to contend with water on the streets.
I think you'd be happy with 33x10.50's, and they'd look good on the Jeep as well. Don't forget to post pics when you get your new tires too. :)
Reactions: fourmustangs
Are 3.73's ideal for an auto? I don't have any complaints w my 3.73's and a manual. But when I finally get to putting in a locker, I'll be changing my gearing as well. Looking forward to feeling the difference.
No. You don't say what model year you have but if it's a 2003 or newer, that automatic is the 4-speed and 3.73 would be horrible for 33's. The 4-speed automatic's overdrive drops the RPMs by roughly 1/3 which means your engine would be lugging on the highway in Overdrive. If your TJ is a 2002 or older, that automatic is the 3-speed which would work a lot better on the highway since it doesn't have an Overdrive to drop the engine rpms excessively like the 4-speed does.
There is an optimal ratio for 33's but you'll have to tell us what year your TJ is. There is a Profile for your Jeep in this forum that you can fill out with all your Jeep information for future questions. :)
Stick with 31's, take those 3.50" coil spacers out, and replace those tired out springs with some new OME 2" springs and rock on.
Your wife will appreciate not needing a step ladder to climb in to drive it, and the 31's will give better road manners.
I do like the current height so I dont want to go down....she likes having to climb in a little
Reactions: SPECWAR
I have a 2004 auto with 33x12.5's, 3.73 gears and don't have any complaints - more than enough power around town. Occasionally at freeway speeds if there is too much of an incline I might turn off overdrive for that stretch, but other than that, no problem getting up to freeway speed and cruising at 60-80mph...
Technically you aren't really at 3.5" of lift due to the factory isolators being removed which are about 5/8". That and your springs are likely sagging with the doubled up spacers. You may be able to get away with 33's on road but have lots of rubbing off.
Reactions: CodaMan
You might go measure your coil springs and spacers to see how much lift you REALLY have. Honestly, it does not look like a 3.5" lift. I think your stock springs are sagging badly. Stock front is 12" and rear is 8". Measure from bottom of spring to top of your spacers, since you don't have any rubber coil isolators. You'll want to get some when you make a change. As someone mentioned, they're 5/8". If you find out where you really are you'll be better able to gauge where you want to be and what to buy. I had stock springs with a 1.75" spacers and my fronts were 13 1/4, so I was sagging 1/2 inch. When I took the spacers off and put on a 2.5" OME my front jumped to 14 3/4". It's so much better
