they are connected and the relationship cannot change, so castor control is pinion control and vice n versa, no?
i had set axle mounting points and only played with what would be the frame end mount points.
we are pulling the lower off the riser up front it ends up a little lower below the frame rail this suffices to lowering that angle back into the chassis. this and your BL then allow all that separation to the upper mount, yes?
what would happen if we strung a line from our link bolts on the axle end 30" out, inline through the frame connection points?
then pull the lower line down to where we can attach the bracket on the rail, and then bring the upper down keeping it in the same relationship.
Not following. The mounts go where they need to go to create the desired relationships.
Preserving caster throughout the suspension travel is nice because the handling doesn't change when you are barreling down the trail at a high rate of speed. The pinion is going to be fine because it isn't going to exceed it's range of motion, unless things are poorly setup or you have some ridiculous amount of shock travel.
