Soft top suggestions
BendLarry
Bend, Oregon, United States
I have a 2006 Rubicon with factory hardtop. I don't want to buy the frame and other hardware to have a factory looking soft top. I'm thinking one of the frameless types might make sense. It will only be used while being towed behind the motor home and then removed when we get where we are going. Only will re-install if it rains. The Jeep is always in a garage and will have the hardtop back on in the winter.
Any suggestions for a brand or style? I think any frameless requires buying a windshield and tail gate bar as well as door surrounds. That's about all I know. Any help would be appreciated.
You basically have two good options for frameless. Bestop or Rampage.
Both will use the bestop tailgate bar and door surrounds (which are same as OEM and you can try to find used on CL or eBay if you get lucky)
Amazon has the best price for the Bestop Door Surround kit new which comes with the tailgate bar.
The Rampage one uses the Rampage Header channel (Around $40). I think the bestop one just latches into the factory header using the same clamps as the Hard Top.
I have the Rampage one and I love it. You cannot go wrong with the bestop version but it is more expensive and IMO more complicated than it needs to be for a frameless top.
There are other companies making frameless soft tops now, but I wouldn't waste my money on any of them.
Very good info! Thanks
https://www.amazon.com/dp/B004P23VNW/?tag=wranglerorg-20
I prefer the factory style framed soft top myself. They can usually be found fairly cheap on CL. I found one complete for my jeep for $100. I did have to purchase door surrounds but those can be found too used. I flat tow my rig too, and it's nice to have the option for top up, top down driving while traveling.
Reactions: BendLarry
Thanks Chris good info with your link. I'm leaning towards the Rampage frameless. Looks good and the price isn't too bad.
I have the Rampage frameless and I love it! If you go with the Rampage, make sure that you wait for a hot day and lay the soft top out for an hour or so before you try to install it. It's a pain to install if you don't heat it up first!
Sent from my iPhone using Tapatalk Pro
I have the Rampage frameless and I love it! If you go with the Rampage, make sure that you wait for a hot day and lay the soft top out for an hour or so before you try to install it. It's a pain to install if you don't heat it up first!View attachment 14946
LJ RUBICON..... DROOL. :sidra_1:
Thanks for the picture.
Reactions: brown_mule
I run a Pavement Ends (Budget version made by Bestop) and it is nice. Easy to install, no leaks, does not flap around. The difference between it and the front line Bestop is the thickness on the materials. You will need the tailgate bar, some kind of door surround, and factory style header. It was around 350 from Amazon when I bought it.
https://www.amazon.com/dp/B00FB0UYZU/?tag=wranglerorg-20
Around $600. With surrounds header and tailgate bar. Close to the Rampage price
I was going to go frameless as well...but I wanted Bestop and as you've seen, they are not cheap. I like the option of unzipping the windows in a frameless top and essentially having a safari top. Anyway, I found a factory softop on CL for cheap (135 bucks) that was complete with all hardware and two door uppers. Still haven't found a set of half doors reasonable though...
I have been watching Craigslist for a while and all I'm finding is junk and I really don't like the look of the frame when the top is off.
Reactions: bobthetj03
Stay away from Rugged Ridge, zippers come un-stiched from the fabric immediately, and it leaks around the doors. I'll be getting a bestop when I get sick of this one. I wouldn't have it but PO put it on before selling the Jeep to me.
Sent from my Pixel using Tapatalk
