I started the regear on a HP Dana 30. out of a 99 XJ. The pinion that was in it was marked +1 and only had the oil baffle installed behind the rear bearing race. The oil baffle measured .015" thick. The preload shims measured a total of .060" thick.
My new pinion gear is marked 2.261"
I'm trying to calculate what the approximate thickness of depth shims I would need on my new pinion. I will be using a setup bearing race, but would like to get somewhere in the ballpark on the first try.
Not knowing what the "standard depth" is on a Dana 30 HP, I cannot properly decipher the 2.261" number.
Anyone know what to do with this?
Thanks
Thanks
