Looks like you are missing A/C. All your other selections are great.
Check the Holly conversion set up. Works great for me.I have the provisions for A/C but I need to first figure out where there's room to place the compressor before mounting it on the accessory drive. That will also determine which pulley offset I go with.
Do you have a link? If I remember correctly they have a compressor with the Corvette (CTS-V) offset and one with their own offset (which is massive). Unfortunately they place the other items such as the alternator in the way of my differential.Check the Holly conversion set up. Works great for me.
www.holley.comDo you have a link? If I remember correctly they have a compressor with the Corvette (CTS-V) offset and one with their own offset (which is massive). Unfortunately they place the other items such as the alternator in the way of my differential.
www.holley.com
Holley Accessory Drive Kit
Part Number 20-133
Mine works absolutely great with no problems.
I agree with you 100%. I have built many hot rods and refuse to have a high A/C or alternator. But no choice with the Jeep. On top of that does it really matter with everything shoved into a Jeep.Awesome. The other one I noticed from Holley is the low mount one: https://www.holley.com/products/ls_...ount/air_conditioning_drive_kits/parts/20-160 I'd prefer having it down low but I need to see where I have space.
Looks great. Is this trans swap not viable for a 4.0, 241 combo?When I was researching the 6L80e I couldn't find any comparisons to the 42RLE so here's some more pictures with them next to each other aligned the same.
This picture is a bit deceiving due to the perspective, but the small area that shows through on top of the 6L80e is the biggest area of difference:
With the pans sitting on the same level surface, the centerlines (ie. input and output centers) of both transmissions are at roughly the same height.
And lastly I washed the engine bay and my garage floor before pulling the Jeep back in:
Tox,
Here is another toy for ya and with that fancy transmission it might even be usable... Damn my 46RE
https://www.powertraincontrolsoluti.../Products/Electronic_Shifters/Paddle_Shifter/
I was eyeing paddle shifters but I couldn't figure out a good way to do it and keep the air bag (priority since I don't want to wear a helmet everywhere). I settled on a tap shifter though.
That's kool I just know if I had a newer trans I'd be looking at this hard. I'd like to be able to tap shift it. The only thing I'd not like is going from drive or 1st to reverse in a hurry.
Reverse will still be controlled by the position of the shift lever in the gate and not by the tap shift. I have my own recipe I've been cooking for a modified rock gate so I can do a quick shift into reverse when necessary but still feel the positions in the gate.
I haven't read through this completely but just want to offer a suggestion for accessories drive. I have two buddies running this set up (non Jeep applications) both had very tight engine compartments. From what I can tell in person, it tucks everything in nice, tight and high. The price is steep but may fit the build. There are various options avaliable.
https://www.holley.com/products/ls_...id_mount/complete_accessory_kits/parts/20-185
