Universal Anti-Rock Rear Length
suicideking
TJ Expert
Riverside, CA
I want to order a rear universal anti rock and there are different width's to choose from. Which one should I order?
Do I just need to measure the frame width? Assuming I need the outside width? I was going to measure last night. Wife borrowed the tape measure...
https://www.rockjock4x4.com/universal-antirock-sway-bar-kits
I've tried emailing and calling Rock Jock, but no answer or email reply for the last few days. I'm sure they're busy.
I have a 10% off code if anyone wants it.
mrblaine put the 45" Antirock on my LJ but I believe he had to bend the arms out for clearance.
Reactions: suicideking
The arms were shortened to 16 1/4" as well. I don't know the length that he started with, though.
Did you get steel, aluminum, or the forged? I have the aluminum up front, so was planning to do the same in the rear.
They are the older flat steel style. I have the ORO SwayLOC up front but I would have gone with the aluminum front and rear as well because ... aluminum. Now that I think about it ... :LOL: ... I think my set-up is due to the coil overs. mrblaine used the newer style forged arms on Nickgsjeep and if I remeber correctly they had to be bent and were a bitch to bend in his shop press:
Reactions: Nickgsjeep
They are the older flat steel style. Now that I think about it ... :LOL: ... I think my set-up is due to the coil overs. mrblaine used the newer style forged arms on Nickgsjeep and if I remeber correctly they had to be bent and were a bitch to bend in his shop press:
Yeah, I read that the forged are a pain in the ass.
