How much stronger is crossover steering?
Eddie Greenlee
Mississippi
Good morning folks.
im wondering how much stronger and effective the “ crossover steering “ is ? I know I see it on a lot of newer Jeep’s and on the dedicated rock crawlers and bouncers.
It’s not any stronger at all. It’s also a poor idea for your TJ if you’re running factory axles, see this thread:
https://wranglertjforum.com/threads/what-is-the-best-steering-for-my-jeep-wrangler-tj.2956/
The reason you see it on a lot of those rigs is because they are running aftermarket, wider axles. That requires an entirely different steering setup as the factory steering will no longer work.
Doing this with your factory TJ axles is not only a solution to a problem that doesn’t exist, it’s also opening things up for a lot of steering related problems.
That and I’m not sure you could pay me to run anything from Steinjager.
thanks, I was just using the picture as an example. I should have said that , ha I dont even know Steinjager. So couldnt atest to good or bad.
The best steering you’re going to get for your TJ is the Currie setup, hands down. The crossover setup is what most do when they go to full-width axles due to having to custom fab a steering setup.
As mentioned in that other post, they are inherently more prone to death wobble.
Reactions: Eddie Greenlee
Hey Chris, what axles and steering are you running now?
X2, and add bump steer.
Honestly I have had nothing but problems with my currie steering set up with it hitting my diff cover and causing bump steer. I switched to a similar setup to Ruffstuffs "inverted y" except I built mine from scratch and it fixed all my problems.
Your axle was too far forward. Can't blame the steering on that.
Reactions: motomick76
No, you have and had problems understanding why stuff has to work the way it does. I also doubt very seriously that you have inverted Y and instead have inverted T unless RS started a new product for the TJ I'm not familiar with. That and you added a heretofore unknown dimension to bump steer and that is sorta special.
But, I do have to ask what trackbar you are running since that usually gets hit first when you are unfamiliar with how to set a rig up.
I stand corrected you are right it was an inverted t, not y. You are correct, in the beginning I had no idea what pieces went with what. The stock steering geometry is not ideal for hydro assist (based on the research i've done and the people i've talked to ) But since the inverted t is better suited for the assist. I had problems with my currie with bumpsteer and hitting the ox locker diff which is thicker than stock so my problems came from pieces not fitting together. But to talk about track bar. I made my own since I made my mounts (axle side and frame side) to allow the bar to be the same length as my custom drag link. Had to make the custom drag link since I made my own frame in the front. I raised the frame and got rid of the front body mount under the grill, took an inch out of the whole front clip, inch out of the steering shaft, rotated my steering box, and made my own pitman arm (similar to the genright one but mines not rotated like theirs) . The whole front end is completely custom besides copying the ruff stuff inverted t set up . and @jjvw my front axle isn't pushed forward, arms are set at stock length and hence why I cut an inch out of the front clip to help the tires clear the back of the fenders
IMG-1529.jpgStock frame cut
61083378381--CED04514-96F3-4C99-888D-269D127FAEB9.JPG starting the front half
IMG-1655.jpg inverted t
IMG-1565.jpgIMG-1561.jpg cut out an inch
AABAE9D0-A8C6-4CCC-8E79-D397DA9B08FA.JPG track bar installed
E8C02C1F-A23E-477F-91B6-0AF1CD2B4E95.JPG IMG-2219.jpgIMG-2221.jpgseems to work pretty well my opinion
IMG-1905.jpg and sits lower than my buddies on 35's with a 4 inch lift so I think its set up pretty well for rock crawling and daily driving.
And to answer the op, if you are looking for a new steering setup, i personally recommend the inverted t. Both jeeps in the bottom pic are daily driven with it and we both have no complains and both run no stabilizer. (My hydro comes off when the jeep gets home from the trail)
View attachment 213003Stock frame cut
View attachment 213004 starting the front half
View attachment 213005 inverted t
View attachment 213010View attachment 213011 cut out an inch
View attachment 213007 track bar installed
View attachment 213008 View attachment 213012View attachment 213013seems to work pretty well my opinion
View attachment 213009 and sits lower than my buddies on 35's with a 4 inch lift so I think its set up pretty well for rock crawling and daily driving.
Stop giving folks steering advice.
Reactions: jjvw
Why does your hydro come off when you get home from the trail?
Thus the "stop giving folks steering advice".
I had hard time following what he did but the first few photos show currie steering and a modified axle side track bar bracket. I wonder why he had bump steer?
Literal. When he hit a bump, his steering hit, or he slammed the diff cover into the trackbar.
