Changed out my ignition system this morning. Including the cam position sensor.
Looks like you are well prepared for the Zombie Apocalypse...............or looters.Your gonna love those Bartact covers. Funny the things we can use the molle and pouches for. I carry a subcompact in the same spot you have TP. Is the hair spray for you potato gun launcher??![]()
We should start a Bartact thread with the uses and pics........
Yes that’s what’s going in the space on the wall, 4 foot workbenchYou may consider a work bench since you have the space.
How is that rack fitted to your hard top?Finally changed the transmission and transfer case fluid at my father in-laws shop. Been on my to-do for a while and won't fit in my garage.
Never did get the eggs , milk or bread . Oh well tomorrow.4 inches fresh snow last nite , so I packed the gravel driveway to harden up for snowblower then off for a sunny dAy tour . Thru some hills in 2wd then 4wd ,then spun a few shitties . Tried to lock up the brakes for controlled skids and had a ball . Ozark Mountain Daredevils just a blastin. Not bad for an old guy!
Got home sprayed down the upper portion then sprayed the complete undercarriage started the garage heater and fan ,dry now.
You install rails or 'tracks' to the hardtop. Pretty much like most SUVs. It attaches to those. Requires drilling so it's on there good. I tell you, it was scary drilling into the hardtop. No going back from that.How is that rack fitted to your hard top?
Cheers
