When have you gone against the consensus on the forum, and done something to your TJ that you know isn't recommended or well-received here? This could get interesting.
I'll start:
I'll start:
- I have used a steering damper to mask death wobble temporarily
- My shocks currently limit my suspension travel in both directions, and my bumpstops are removed altogether in the rear
- I run load range E tires and 16" rims
- I installed a high flow water pump and 11-blade Explorer fan and clutch instead of factory parts
- My armor is almost all steel
