Here’s my dip stick for my 32RH swap. Can you tell if it’s the correct one for a 2002 32RH trans ?
Stick the dipstick tube in the hole on the side of the transmission. Swing it around until the mounting tab lines up with the bolt in the bellhousing. No other dipstick tube will line up.The number on the dip stick is
8953003661
It does seem to fit,, but of course when it arrived the O ring was brokenDid it fit? Looks like it also needs an O ring at the bottom
I saw that too . Guess I’ll try and get a refund and look for another. Good luck to me haThat kink isn't helping.
Take a hammer and gently tap on the sides of the kink while trying to tweak it back to where it used to be. That should help the bracket line up with the bolt hole. The kink is just affecting fitment maybe and it won't affect how the mess works if you can get it bolted up.I saw that too . Guess I’ll try and get a refund and look for another. Good luck to me ha
Thanks I’ll try thatTake a hammer and gently tap on the sides of the kink while trying to tweak it back to where it used to be. That should help the bracket line up with the bolt hole. The kink is just affecting fitment maybe and it won't affect how the mess works if you can get it bolted up.
Gently, treat it like your girlfriend, not your wife.Thanks I’ll try that
Ok thanksThe mounting tab is pointing the wrong way so it’s the wrong tube. It’s supposed to mount here
Possible, it is very thin metal though.would it be possible for me to take the tab off and weld it the right way to fit ?
That part can be figured out. All we have to do is mark the tube where it enters the trans and then measure how much the dipstick sticks past the end of the tube. That will get it more than close enough to keep the trans working well.Even if you get it to mount you don’t know if the stick reads the correct fluid level if it’s not from a 32rh.
