Or just haul one of your younger kids around all the time...Unless I keep a full tank it;s going to generally ride a bit high. Hmmm....When I take the hardtop off it;s going to get worse. I could strap a couple 45 lb weights in the back.![]()
That would work. I hope they do decide to come more often. Now that we have two TJ’s everyone has a seat. My wife talks about a JKU down the line. I say to her, “It won’t be the same. You want a TJ. If not, at least direct your thoughts to a JL.”Or just haul one of your younger kids around all the time...
Looks great. As the paint cures it will likely match better. The MC fenders I painted started off darker then blended quite well.Time to install the Savvy tailgate armor. The tailgate just looked like crap from the PO and I kept hitting the spare coming out of ravines, so I decided to spare delete and start armoring up.
My paint is not nearly as good as @Alex01, and the red seems a tad darker. I used the PW4 Duplicolor cans followed by lots of clear coat. Meh, it’s ok. I may wrap it someday and should have from the start. View attachment 235967View attachment 235968
Now I need corner armor!Looks great. As the paint cures it will likely match better. The MC fenders I painted started off darker then blended quite well.
On the other hand, check out these Swag Bertha raised body mounts. Look how they don’t have anything that hangs down and liable to get hit and knocked and bent. The angles look better to me, like they’d just slide over something if you hit.
Not all pictures show itBut each and every one has SWAG carved in it - wwwhhhyyy!
You're right, that’s interesting. The boxing in seems nice, but I wonder if it’s necessary and how the measurements compare. They look to me to hang down more, but I just ordered the GR ones so I have a bias I want Confirmations on.Not all pictures show it
NashvilleTJ used the swagsYou're right, that’s interesting. The boxing in seems nice, but I wonder if it’s necessary and how the measurements compare. They look to me to hang down more, but I just ordered the GR ones so I have a bias I want Confirmations on.
If i remember correctly, I believe GR has them mis-advertised and you need 1.25 BLThanks Alex for the Savvy pucks and KC lights. We’re going to have some fun! What a treat!
@Alex01, a question for you. The raised Genright Body Mounts are advertised to replace a 1” BL. We’re all running 1.25”. I’m sure you got around that somehow.
https://www.swagoffroad.com/SWAG-BERTHA-TJ-Wrangler-High-Clearance-Body-Mount-Skid-_p_12.html
By? So you can wear out another sandpaper disc with your grinder.But each and every one has SWAG carved in it - wwwhhhyyy!
What do we do with the inner C’s on the Savvy MUA system? Seems like they would conflict.The GR mounts are advertised wrong. I had the same question why I bought mine and @toximus confirmed the misprint.
The GR mounts will be perfect.
I have a GR universal crossmember so I didn't have any inference issue.What do we do with the inner C’s on the Savvy MUA system? Seems like they would conflict.
Maybe @NashvilleTJ thread. IDK. Page 4 in his thread is where he installed them.I have the SWAG mounts also just haven't gotten to that part yet to install them.
It's been discussed in another thread about why the SWAG mounts are as good at the GR ones but I don't remember whos thread it was in.
