Rusty skid plate bolts
Any local hardware store. Just take one in the store and get a matching thread. Get help from a person who works the floor or lay the threads in each other to make sure they are identical. If you need to drive your Jeep there, put 5 in the skid and you’ll be fine. Buy stainless to avoid future rust as much as possible.
Sorry to overthink this but would they have the conical base? That seems to be a pretty specific item I couldn’t find at HD or Lowe’s which are my hardware options.
I have another vehicle so I am good.
I could always put these in and then order the specific ones online and swap them out later
Reactions: Johnfromphilly
Put those in with antiseeze and be done. In a couple years pull them one at a time and recoat
You should be fine like @never monday said, but you seem to be stressing about it, so the link to new bolts and nutserts above. If it were me I’d anti-seize them and install at 75-80% torque and call it a day.
Thanks for the input. I was more concerned about putting in non conical bolts. I will install the slightly rusted bolts with anti seize and moving on.
Thanks again! I plan on posting a thread with the whole process when I am done as it ended up being a bigger project than expected. My frame shows no rust but there was a bunch in the skid plate- frame connection area. It is a good word of warning to do this project even if it looks fine.
It is a bad design in my opinion. You have a recessed area on the skid plate just waiting for water to get in there and just sit.
View attachment 238294View attachment 238295
I put some motor oil between the frame and skid plate to help prevent rust forming between those surfaces. Anytime you sandwich metal like that it’s a breeding ground for rust
Add a washer between the skid and the frame (as qslim stated on page 1).
With my skids on my 05 and 06 I had to add about three washers before I actually got separation between frame and skid due to the recessed area around the bolt hole. I completely treated my frame to prevent future rust and did not want that skid touching it.
I know you’re done with it, but if you really want to get the blue loctite off, you could probably melt it off with a heat gun or lighter.
