I love that winch plate. I wish I had come across it before I got the one I did.
I did mine about 5 years ago..got mine from a radiator specialist in Onehunga.(brass core works really well)
I got mine from Silverdale Radiators. 3 year warranty so will see how it holds up. Just finished installing it, all went well. Waiting for it to cool down to check levels :)
Reactions: Kiwi TJ
Changed out the split radiator today, took a few hours (I’m not the fastest, like to take my time and poke around while I’m doing it to see how things work)
During:
After:
the hose that goes to the overflow bottle isn’t tight enough for my ocd. So will find a little hose clamp next time I’m out.
Also seen my light under the hood is blown, so will get a new one for there soon too.
Added TJ #4, or 3.5, to the fleet, err, parts pile? I bought a Dana 30/Dana 35 4.10 axle set with some accessories attached. The axles are intended for the 1998 Sport project. I'll probably keep the windshield frame because 3 black windshield frames isn't enough. The tub is salvageable. The frame is crusty, but solid. The wheels are retro, but I kinda dig 'em.
I like those wheels quite a bit. Who made then, you know? What size and backspacing, any idea?
Taking the Jeep for a ride to check this out today. :cool:
2019 Polaris RZR 1000 Highlifter Edition.
Runs Excellent and extremely low miles.
10” Super ATV Lift
8” Super ATV Gen 3 portals
42” BKT Tractor tires
Keller Ball joints all four corners
X300 extended axles with spares .
That looks like a Tomken winch mount, that is what I have, I like the simplicity of it. I welded a rectangular piece of tubing to the top bar and mounted some rectangular lights to it, sturdy and works well......View attachment 239817
What cable set up did you use for thew winch?
I was going to build a bracket to mount the blue sea disconnect but it might be easier to run disconnect wires like you did.
Reactions: TheBoogieman
Just bought some Old Man EMU springs Light Duty (2932 & 2941) and some Rancho Shocks RS5000x (RS55128 & RS55240).
When I find some time, I will install them on my own to give a 2.5" lift on my 4-cylinder 2.4L TJ.
It about time to let those tires "breath".
M.O.R.E. Dead pedal installed real quick like. Thanks to @Stinkbug Shipped to my door for $30. Best that 🇺🇸💥
Also replaced all 4 fuel injectorO rings. Easy enough once i figured out how to remove the fuel line from the rail😁 Thanks YouTube
View attachment 239982View attachment 239983
Thanks for sharing. I love seeing Jeeps and signs from around the world.
Finished up my phone mount since my Tackform bits showed up. Only wiggly when I hit a decent bump, and if I rest the bottom of the phone on the center stack almost no wiggle at all. Thanks to @Fulton_Hogan For the inspiration!
NICE!!
That's very similar to what I wanted to do, but the 2-hole bases were out of stock, or they didn't have the arm I wanted; I don't remember which.
Congrats on the build, looks sweet.
Reactions: bstrobel64
