Track bar bind
Eddie Greenlee
Mississippi
I know , but this is why I don’t like it !
Reactions: D M
Well that one side droops more than the other. It would be cool if they dropped the same
They pretty much droop the same in actual use, because when you're articulating, you're not drooping out both sides - one side is drooped and the other is stuffed. If you jack up the passenger side you'll see the driver side droop some more.
Reactions: Eddie Greenlee
As long as you don’t drive it around on Jack stands , you will be fine. ...other than still being in Mississippi.
A track bar (Panhard) is designed to limit movement of the axle left to right as it travels up and down, and it does it very well. It is a control arm
When you say it is a crawling machine, can you expound. Does it have lockers, a lower ratio transfer case and armor....
Thanks , we eagerly await your reply. All forum activities are on hold.
Well Andy thanks for the intro.
All adj control arms
4.88 gears
Ox in the rear of my 8.8 w/ super 88 kit.
ozzy locker up front and all chromolly shafts.
Bell yup skid , ss sye. Adams drive shaft
So much more ....
How about you ?
Reactions: Blondie70
4.88 gears
So much more ....
How about you ?
V8 on one ton axles with an atlas.
