If these things could bolt on like the AEV brackets for the JK I'd have them already. But I can't weld and I have a fear of making mods I can't undo. So I might be a little slow to adopt these brackets. Even though I think they are beneficial.
I talked with @David Kishpaugh about this a while ago and there are some hurdles that need to be addressed to go bolt on. One is the upper axle brackets on both sides need to have additional welds added or other reinforcements made to prevent the brackets from tearing from the axle tube. That is why Dave just went with the completely weld on path.If these things could bolt on like the AEV brackets for the JK I'd have them already. But I can't weld and I have a fear of making mods I can't undo. So I might be a little slow to adopt these brackets. Even though I think they are beneficial.
@starkey480 ran 9 hours to moab, several trail days, and home keeping the fronts as SA. He has spoken highly of how it performed.Can the rear brackets be added while keeping the front short arm and still see an improvement? Any set up guidance (hate to use the word "instructions") included? @Mike_H have you installed yours yet? Thoughts?
I have not. Not sure I want to post my thoughts here, based on this discussion.Can the rear brackets be added while keeping the front short arm and still see an improvement? Any set up guidance (hate to use the word "instructions") included? @Mike_H have you installed yours yet? Thoughts?
Loose definition of discussionI have not. Not sure I want to post my thoughts here, based on this discussion.
If you all spent half the time focusing on your driving skills instead of what is better, you'd all be better.![]()
I've done a couple short arm outboards with 12s split in half. We have not seen the suspension bind on the trail. On jack stands, yes. But not with the weight of the Jeep acting on the axles.
I'm saying that with a 12" shock split 50/50, the short arm bind is a non issue when the weight of the Jeep is acting on the suspension. I'll go further and say that I see no reason why a longer shock couldn't be used. The arms aren't the issue. After 12s on factory width axles, the inner side wall is mashing increasingly hard into the outboarded shock body that the endeavor of adding more travel begins to not be worth the effort. Plus the jacking on a short arm becomes a real problem where the tire drives under the rig and tears stuff apart. Additionally, I know first and second hand that a Rubicon rear driveshaft on 4" spring lift and a Savvy skid will start to bind and quickly lock just after 5" of down. For some reason this isn't pointed out as often as it ought to be. This is why I put a center limit strap on mine.
And while I know what rear steer is, I have never been in situation where I recognized it as something to concern myself with.
At what point does the driveshaft bind? Unless you're running a dropped belly, my experience is that it happens well before that point.12" outboards matched to a 2" bumpstop extension without geometry correction, the axle will not hang at the bottom of both shocks unless the drivers side upper control arm bolt is removed. There is a massive amount of rear steer under articulation and the suspension binds under articulation before it hits the bumpstop extension. I have a rig with geometry correction on 14" travel. The problem is the suspension binds before full droop but still easily flexes out to the Bottom of the shocks. Same as a 24" extended shock in stock mounts. The binding is what tears up bushings and rips brackets off.
Why does this matter (flipping calipers)? It’s a minor change, so I’m not following why this is something I should consider.I can run a 14" travel shocks on stock axles without flipping the brake calipers and still clear the frame.
The only way to put 14" travel under a tj rubicon is with a 5" stretch. Having a tj rubicon a guy intends to build, there's no advantage at all by running an unstable long or mid arm under it.
Running geometry correction, there's no cutting whatsoever that needs to be done to stuff a 35" tire in the factory fender opening. Geometry correction also fixes the over extension problem the arms have that drags the axle under the body.
My normal set up with a 2" drop skid and geometry correction is 15.5-15.75" lower arms. It's not necessary to run them 16" or more, all that does is create clearance issues.
As far as the shock and frame contact with 12-14" travel shock, I solved that issue as well with the shock towers I build and specic positions. I can run a 14" travel shocks on stock axles without flipping the brake calipers and still clear the frame.
Different prioritiesAt what point does the driveshaft bind? Unless you're running a dropped belly, my experience is that it happens well before that point.
Edit: Nvm -you said you use a 2" lower belly.
I would, but I haven't done or seen an outboard without a caliper flip. I'm just not sure why one wouldn't flip the caliper since it makes the job a bit easier.Your response applies to Rasband's caliper question too.
From the comments here from those who have this, this is a bang for buck solution*, and it costs more to flip the calipers (or rather parking brake).I would, but I haven't done or seen an outboard without a caliper flip. I'm just not sure why one wouldn't flip the caliper since it makes the job a bit easier.
12s using bushings? Why?
14s on short arms? Why?
And I keep asking people to explain how exactly rear steer affects anything.
And I haven't seen an outboard where the tire contacts the frame.
Shock outboard without a caliper flip https://www.stu-offroad.com/suspension/rearshock/rearshock-4.htm done by Blaine himself. Caliper flip was an improvement on the process that Blaine came up with later.I would, but I haven't done or seen an outboard without a caliper flip. I'm just not sure why one wouldn't flip the caliper since it makes the job a bit easier.
Man I was out there yesterday in 100 degrees wheelin. I’m workin on it!If you all spent half the time focusing on your driving skills instead of what is better, you'd all be better.![]()
