Looks like you're off to a great start! I'd look into Armor underneath. If you haven't added anything, the oil pan is completely exposed. A Tummy Tuck is a little pricey because of the need to eliminate the Slip Yoke, replacing the drive shaft, replacing the motor mounts, & lifting the body, but I was able to gain 3 1/2 inches under the jeep and making the jeep completely protected and flat underneath. It allows you to slide over boulders that would normally be damaging expensive components. I want to say my total spend for the tummy tuck was about $900.
Some quick disconnects are a really cheap upgrade that really improve offroad capability if you're not ready to drop $400 on antirock swaybar. but with a 4" lift and disconnects, you need to also replace the front brake lines with longer ones.
I ran an ausi locker up front for a while, it made a difference offroad, but not nearly the difference of having a locker in the rear. Definitely would not do ausi in the rear though, the noise will drive you crazy after a while. I ended up putting an eaton e-locker in the rear, and liked it so much I replaced the ausi up front with the eaton. I ran 33's on the original 3.73 gears, but when I went to 35's, it was just too gutless. People will tell you your crazy for running 35's on a Dana 30/35 combo, but I've been doing it for years running some really tough trails without problems. I just don't let myself bounce, if I can't make it locked, I back up and try another approach.
I'd also consider armor under the gas tank. The stock is way to thin and if you come down off a ledge and smack your fuel pump or puncture the tank, it can wreck your day. Not that it will explode, you'll just be dead in your tracks.
thanks for the input, yep ive got about 1000 places for $1000.00 to go ha, Id love to do the sye/ford 8.8/CV drive shaft......one day. but i have extended my brake lines (both front and rear) so thats a step in the right direction. i do not have an oil pan skid plate.(ya might recommend one for me). I know the anitrock is supposed to be the best for off road and daily driver for articulation and safety. but i guess with caution, disconnecting is a good deal too for off road.
