Is this for an lj or tj? I seem to recall someone saying that for lj all u can get is the trim to fit. But thats like 3rd hand speculation. Have you contacted acc directly? They are a fabulous company to deal with. They sent me 5 color samples for free. And answered all my questions.
Mine seemed to be slightly bigger than my original. But not all Jeeps are the same. And i think its better to have to much rather than not enough.
It also seems like acc is meant to go in with some velcro or spray adhesive to line all the way up and over stuff. It seems to cover more. And also seems to be a carpet that the seat brackets etc sit over the carpet for less exposed areas. Also meaning ita more of a caroet to put inplace and leave. Rather than bedrugs easy ability to be removed and replaced.
I just want to add that after installing sound deadener and heat shield. I could have gone with bedrug no problem. I was just turned off by the price. ACC is so much less expensive. If your not getting mass backed.
I prefer sound deadener attached to the tub vs mass backing. But if your adverse to it. Mass backing is a step in the right direction. You just wont get the same results as sound deadener attched directly to the tub.
If you compared just cutpile without the mass backing to bedrug. The price difference is significant.
No matter what i would put down at least heat shield. As there is so much heat generated below the tubs centerline. Its cheap and light. Goes down with a light coat of spray adhesibe. So easy to remove. Unlike sound deadener.
Www.carinsulation.com
I did see a frienda bedrug in his truck this week. Its very nice. Berber type carpet. Like looped not cut. With sewn trimmed edges.
