I'd settle for a semi-complete parts list of the major parts and some slightly out of focus pictures!If he can give us some sort of write-up, I'll happily add a link to it on your FAQ post. That would be awesome!
I wonder if this is the controller he is talking about?
http://www.aemelectronics.com/produ...gement-systems/fuel-ignition-controller/fic-6
There's always the Bosch 4 hole injectors. We may have finally found a use for that mod.Interesting, I'm going to assume it is.
I don't see why it wouldn't work either. It's just a piggyback fuel controller. All you really need to be concerned about when adding a turbo would be the extra fuel necessary when under boost.
You'd probably also want some larger injectors as well.
I have to send those guys an e-mail and see if their controller will work with a Roots or Paxton style supercharger. For a TJ, it would be nice to get increased HP and torque from right off idle.
...and spark timing.I guarantee it would, no reason it wouldn't.
It's only job is to control the fuel.
You just have to find a way to mount the supercharger, which really wouldn't be that hard with some welding skills (you could fab a bracket). Then you just have to make sure all the vacuum lines on the existing manifold are moved above the supercharger, that way you aren't pushing boost into the vacuum lines, haha!
Yup, you are totally correct. Gears and weight reduction are the only ways to get more performance out of the 2.5 equipped Jeeps. Unless you spend a ton of money. An $800 turbo setup is interesting though. That's less than a Super35 with new gears or a decent suspension system.the best way I've found to make the 4cyl feel peppier, besides gearing, is to loose weight...but admittedly I've not done any kind of forced induction
on my 2.5L YJ, I run a 5spd, soft top, half doors, no A/C, aluminum front bumper, aluminum skid plate, synthetic winch line on a light winch, alloy wheels, no rear bumper, and no back seat..been thinking about a 'glass/plastic hood, speedglass for the windshield, aluminum drop down tailgate, and full soft doors to lighten it even more
another added benefit to going lighter is less strain/breakage on the drivetrain, unlike a turbo or supercharger
Going from a vacuum to 6 - 8 psi is a lot of additional air / fuel mixture.I wouldn't worry about engine longevity or reliability as long as you're running a reasonable amount of boost (no more than 8 psi).
If you want higher boost levels, you'd need to rebuild the engine with lower compression and forged internals (obviously).
But 6 psi or so on the stock engine would be just fine I think.
Details and pictures please! For $800, I might have to eat my words on upgrading the HP in a 2.5.
Nice! Thank you!Turbo build price and parts.
Here are the parts and cost from ebay, t3/t4 turbo compressor trim 55, inducer 50.5, exducer is 76, a/r 0.5 cost $125.00. Header $145
Turbo oil lines return and feed $35, Silicone Couplers $50, Intercooler $88, Aem FIC module $350. I used 2.5" exhaust pipe for very thing.
It would be a nice thing to add to the FAQ on the four angry squirrels making more HP thread. If @Neumeyer has figured out how to make the 2.5 put out for $800, that's a breakthrough. I'm in.
