Just installed MC dual rate springs to take the place of original Rubicon Express springs. I'm running JKS Acos adjustable bump stops front and rear. In both cases the circumference of the spring at its widest point exceeds the spring bucket or stop at the top of the adjustable Acos...(see pics). This is essentially the same condition that existed with the Rubicon Express springs. Difference is with the RE the distance between each of the the coils didn't draw your attention to the condition as much as all of the top coils on the MC that are compressed together. The dual rate springs are obviously "softer" at the top by nature to compress together and then expand when the wheel on either side droops keeping the spring seated at the top and the bottom. I'm wondering if this softer material or rating at the top of the spring (especially in the rear when loaded with gear) is now a weak point? there's no full width bucket at the top of the spring for the larger circumference coils to rest against during full compression and absorb some of the load. The first and smallest turn of the spring at the top will absorb all the pressure. I realize the bump stops will be set to prevent over compression of the spring and shocks....just looks funny to me. Should I fabricate and place a full width bucket or cover to go on top of the spring where it meets the Acos?
Jeep is pretty heavy with full roll cage, accessories, cooler full of beer, blah blah blah....
Thanks for any input.....
