Frame side track bar mount bent
It can be done but like the rest of the retarded shit in this world, we all need 1000 dollar answers to 10 cent problems. Stupid fuck ought to go to work for MC.
Go find a 10 cent fabricator that will heat and bend that properly. Then weld to the forged mount.
The OP just solidified my answer with his own response about the articulation limitation of his current TB. You can see the lack of misalignment there. It is a limiting factor in that position.
Not too hard to get the geometry right with a a DS mount either and cost a lot less than what you are implying.
  • Dislike
Reactions: Lou
You think he bent the mount because he has too much articulation?
Yes very happy with my alignment and the way it rides now, the only real issue is the limited articulation with this thing at it's limit :(
The only limit is when the left side goes up and the right goes down or full droop. My bigger concern would be how it got that way. I suspect there was a front end collision of some sort that tagged the axle hard. I'd be more worried about the frame being shifted in that area than anything else.
Reactions: NashvilleTJ
This is exactly what happened, PO said the jeep got tagged right at the wheel which pushed the axle, had the jeep checked out at a few body shops and that's where the bending back idea came from but wanted to get some ideas from actual jeep folks. I'm not new to jeeps just to tj's but I'm learning! One of the shops said it's lucky that mount is so weak in that it stretched instead of breaking the welds or tweaking the frame.
Did they repair the axle or replace it? 99% of the time it folds the lower control arm mounts over, bends one inner C at least and then typically tweaks the long side axle tube.
Mr. Blaine you're like a mind reader, so yes when I got this tj, the drivers side c was bent as well the upper balljoint, camber was like 2 degree's in. I've since replaced the whole axle with a mint stock one trussed, replaced the whole front end steering links, pitman arm, the whole shebang (before posting here I've been following you and Jerry Bransford's recommendations, spicer ball joints, wj steering upgrade, I'm usually not the smartest guy in the room but I recognize who is) going to do a build posting so I can get these 20 post out of the way :)
Reactions: Tob
Nothing to do with reading minds, just seen the aftermath of a lot of traffic collisions.
FYI, if you trussed it, you weren't following my advice.
