Drudging up an old post here….. I’ve addressed/fixed my darting issue (it was bad sway bar links - they’ve been replaced), but I’m still dealing with some steering wheel play.
Steering wheel still has about ~1” of play either way (11:00 - 1:00) that doesn’t do anything with the wheels. When I turn the wheel in the jeep, the upper/lower steering moves with it, but the pitman arm doesn’t move. This is the case when it’s started, or turned off. Most of the time when I’m driving down the road, the wheel is either at the 11:00 or 1:00 position when driving straight.
I have replaced the steering box, and verified that all bolts are properly torqued. All tie-rod ends are new, as are the track bar, drag link, tie-rod, upper/lower front ball joints, and pitman arm.
Any ideas?
