Gave it a bath [emoji23]
here is a little perspective...JK rubicon takeoffs...obviously the installed clearance would not be quite that tight...but still. I'm hard pressed to believe that they would fit without modifications.
KqO9F9ei5LR47rFWVBorhNaEzMaefz1W232WMO9RvOvMZeJl-w6f11GjGeyiVJVI3POpl_oijSd0FS3S30=w1135-h638...webp
6PQyDeWYrh7uQM1SOlDDkIurPnHuVRJUFvrwTQ0ZtwAWQzygckf3gbrcfyUKmrzf7bpd9f1BOsNaVPZFL0E=w359-h638...webp
Reactions: Tj04
Reactions: StG58
I've been looking at the tier 2 core 4x4 control arms. Real Currie JJ on one end, Clevite bushing on the other. About 750 bucks. Looks like a quality unit. Hard to make them yourself for that price. I'll either do those or drop the 1100 bucks on dbl adjustable aluminum ones from Savvy.
What's the difference between the tier 2 and tier 3?
Those are great control arms. Get the tier three. I love mine. They are beefy as hell. Pay the extra money for the Currie Jonny joints. Lifetime warranty so no harm done if you got the tier one.
They are super underreviewed and many don't buy them as not many have reviewed them. but don't let it scare you. I sent many emails to them before buying and they are a stand up company with great customer service. Made in the USA in Colorado.ill be making a good review for them when I get some good pictures of them on some rocks or something.
Reactions: StG58
QUOTE="CodaMan, post: 98449, member: 2727"]What's the difference between the tier 2 and tier 3?[/QUOTE]
Here's mine in case anyone wanted to see what they look like on a Jeep. I did put them upside down on purpose. Asked if it would work and they said under or around ~2 inch lift is fine but they were made to go other way. Jonny joint should go on frame end but also didn't matter.
Sorry about my shitty skyjackers and white mud.
Reactions: StG58
@Ranger_b0b how did those Jk rubi tires fit? I assume youre going to opt for a soacer adapter? They look great. Do you have 30s now?
I don't have them on yet...will be going on this wknd. I have 3/4" spring spacers to get me through the next month or so, until the weather turns. Then the jeep is going into my heated barn, for winter work. I'm also going to run 1.25" wheel adapters. Because of the offset difference between the TJ Moab and the JK Moab, the 1.25" spacer will put the wheel within a quarter inch of where it currently sits.
Reactions: Tj04
