@hosejockey61
Butt welding sheet metal isn’t bad, just time consuming.
That early Bronco is probably 18ga like my C10. I did rockers (inner&outer) floor pieces, cab braces, toe kicks, cab corners, etc. Never did that kind of welding before that and it ended up just fine. I started with the floor pieces to get my technique figured out.
I found that good results depended on a combination of things:
*Having the right gap, the thickness of a dremel cut wheel was about perfect.
*Doing 2 and only 2 tacks at a time. Seriously don’t try 3, it won’t work reliably.
*Move around and don’t let it get too hot.
*Be careful at the corners. 1 tack and come back to it later. The corners can have little to no gap.
*After you weld and grind, shine a bright light behind the area and you will find your pin holes. Mark em with a sharpie and hit them again. Repeat as needed.
*Use .023 wire. Don’t even fuck around with the .030.
Enjoy.
