I try to avoid the term "Heat" in reference to settings because it can be confusing. A cold weld means your settings in general are too low where a hot weld is the opposite. Also the type of machine (inverter based or transformer based) you have would help me understand better because they operate a bit differently
For the specific welds you posted, the shorter one looks really consistent while with the longer one you were just moving too fast. I wouldn't change the settings just adjust your travel speed. Learning to adjust the way you weld as opposed to the settings will make you a better welder. This will teach you how slight adjustments on your end can affect the weld in different ways, it will teach you to read the puddle & will really benefit you when your welding in awkward positions.
I have a Lincoln 210MP. Thanks for the explaining on wire feed…your second paragraph stated something that I’ve noticed. I really struggle to get a concave bead. I’ve tried slow travel, fast travel, etc. the bead just piles up, if I move slow, it’s a fat bead, and if I move too fast, it’s thin and ropey.
I’m not consistent in my welds, so I’m not saying that it’s all machine. I just wonder if my feed might need to run a little faster to help out. Honestly, it’s been a bit frustrating, because no matter how often I try, I can’t get that concave shape that I want.
