Where did you buy a harness? I've been looking on eBay and I've found the one I need for 350 to 400 dollars!
Face book. Kept looking for an identical harness by number. What harness number are you looking for?Where did you buy a harness? I've been looking on eBay and I've found the one I need for 350 to 400 dollars!
I paid $160 shipped. Cost the guy $53 to ship it.Face book. Kept looking for an identical harness by number. What harness number are you looking for?
56047 201 or 203 are possibilities. I'm doing a transmission swap, so I need a different one than I have. I may have to add circuits based on options, but that is as close as I can come with the resources I have. My Rubicon is pretty loaded, as far as TJs go. No Gentex mirror, but the wiring is there.Face book. Kept looking for an identical harness by number. What harness number are you looking for?
I asked he said it wouldn’t fit. Lol. It was the PDC box /harness and a 6cyl harness. Will start going through it later to make sure I have the correct diagrams.WOW, WTF how did he ship it? That is crazy. Guess he didn't know a harness will fit into a large flat rate box.
You doing a Hemi swap or just trans?56047 201 or 203 are possibilities. I'm doing a transmission swap, so I need a different one than I have. I may have to add circuits based on options, but that is as close as I can come with the resources I have. My Rubicon is pretty loaded, as far as TJs go. No Gentex mirror, but the wiring is there.
Still waiting to see if I find a complete manual/engine donor rig or a just trans first. Seems to be easy to find a running rig with a 5.9 with a bad auto tranny though.
Just a trans. My 3550 is starting to shift hard anyway... So why not put an auto in!You doing a Hemi swap or just trans?
The box it came in looks no bigger than a flat rate box. We agreed on 160 shipped before he found out. Not sure he knew any better.I wonder how much different a 4 cyl is from the 6 cyl? If it's only 2 injector wires I wonder why it wouldn't fit?
I would just get the running auto tranny rig and then blend the two harnesses to make your manual harness. Shouldn't be super hard. Both the Dodge and Jeep harness I bought were shipped in a large flat rate box.
It easily would have fit in a large flat rate box I just got one out. I ship quite a lot through my side gig.I've made that mistake because I was use to OLD shipping rates. Don't do that anymore.
This is most likely they way I will go. Hard to find a running manual trans rig in the donor price range. Lol. Several 5.9s with clapped out interior and bad auto trans that run for less than $500. Since I’m planning on a rebuild before install I just need something that runs decent without any knocks or heat issues.I wonder how much different a 4 cyl is from the 6 cyl? If it's only 2 injector wires I wonder why it wouldn't fit?
Ya. Most likely I will leave my current harness alone there and just pin it into my frankenharness. No need to rewire that stuff.Dang that is the part of a wiring harness that I need to make mine look better. The harness to the speed sensor & fuel pump/sender.
