2000 Jeep Tj 2.5L
-Brand new X2 battery from batteries plus
-Brand new big 7 wiring kit
-refurb alternator from oreilys 7 months ago
Was doing some tests on all my electrical since i had an asd issue and noticed my battery was dead 2 mornings in a row. It was time for a new battery anyways since my prior one was 10 years old.
New battery unhooked 12.6 Volts (multimeter on pos/neg battery posts)
New battery installed with new cables 12.6 volts (multimeter on pos/neg battery posts)
While running sits at 14.7V for a brief moment then climps up to 19+V (multimeter on pos/neg battery posts)
Battery guage on dash reads 13ishV
aftermarket battery guage wired to cig lighter 13V
SO i was playing around with the multimeter and was testing to see if my grounds were good.
-Neg on battery, positive to firewall bolt where ground is attached no resistance
-Neg on battery, positive to grounding bolt on engine block, 2 or .2 not sure on the setting
What do i need to test next? Is there any other sensors i need to check? No CEL either.
Thanks in advance!
Thanks in advance!
