Hey I am new to the whole forum thing and to be honest I usually avoid them like the plague but I have come to a crossroads and don't have anywhere else to turn. That being said I apologize ahead of time if I lose anyone in all this.
I am wanting to learn more about engines, transmissions and really the guts of a vehicle so I figured what better way than to do it myself. I told myself that if the engine or transmission got into a bad enough condition that I would start working on a 350 engine swap. Well as of recently my transmission has started to go out.
First things first, a little bit about the vehicle. Right now I have the 4.0 I6 with a cool air intake and a 3 speed auto trans. What got me looking at the trans in the first place was that the overdrive gear started acting a little wonky on my 14 hr drive back to Abq. When I checked the trans fluid it was pitch black. My biggest fear is that if I do change the fluid it might get progressively worse and fail quicker than if I leave it alone.
Secondly I would like to do a 350 engine swap with either a 5 or 6 speed manual transmission. As far as the engine I want to do. I'm thinking the 5.3 l33 aluminum block since there is still a lot I can do aftermarket on top of the fact I would be losing weight and gaining hp. I'm having more problems figuring out what transmission to do more than anything which is unfortunate since that is the first thing to be going.
Now during my research online of trying to figure out everything I wanted to do. I got a little overwhelmed and started asking some people I know. Something that was brought up to me was running a turbo 400 but since I can't really find any stock manual 400's I don't want to do that. The other trans that was brought up to me was a TR6060. Since that one I can run in either 5 or 6 speed I am pretty positive that is what I want to do especially since stock it will handle most any aftermarket I would ever do to the engine. I have looked at Novak and that is how I came across the l33 and did a lot of reading on there as far as doing swaps. They were very knowledgeable but I still have some questions.
Something else that was brought up to me was that since I would end up swapping the trans first is that I can actually get away with throwing in the TR6060 with out having to worry about anything getting messed up. Is that true? Obviously I would still have to do some modifications because I would go from the stock auto trans to a new manual trans but can I actually get away with that. Also does anyone have a good reason that the engine I have picked out wouldn't work with the TR6060. In the end I am just looking for some opinions and help figuring this out.
