If you go through Engine Masters content you can see what difference 2.5 vs 3.0" exhaust delivers. May or may not change your mind.I used the 2.5 exhaust.
That seems a bit on the low side unless you're heavy with the right foot. Could a gear change put you a more efficient rpm? This is from a 2001 5.9, but I'd imagine it's pretty similar across the years. If you can get your cruising rpm above 2000, the you've got alot more power available on throttle tip in which should keep you in more efficient closed loop running.For what i do, the 5.9 is very impressive a d more than I need.MPG is not the best as I get about 11 MPG.
