I'm going to replace them with 3 wire button lights and put them in the same area as @DrDmoney. The stock 2 wire they sent only works with the headlights on or off, not both.What did you do with the side marker lights ?
Imagine if you had more lift and shorter arms.I was able to push the axle 4 rotations forward. I had to modify the TB a bit but it clears now. Crossing my fingers I didn't take out enough to cause any issues down the line.
Wheelbase seems to be exactly 93.5" so I'm not quite sure what I accomplished pushing the front all the way forward and the rear all the way backView attachment 230833
HuhThe MC fenders allowed me to run a good amount LESS bump stop than the GR fenders. With the new fenders I'll need to add 3/4". At least they look nice
Alex - that actually looks pretty tight in the rear. Have you flexed it at full stuff / full lock?Yes. Tire is on the upper edge of fender. Tons of rear clearance.
I haven't touched the control arms yet.
I did, I made that comment without thinking of turning so "tons" isn't accurate. I have enough room to turn the tires at full lock. Not much but enough.Alex - that actually looks pretty tight in the rear. Have you flexed it at full stuff / full lock?
Huh
but I thought everyone said metal cloak didn't offer any extra clearance over a tube fender.
Alex,About time.
Me: (like 6 months ago to Alex...) I think you should start a build thread.
Him: my builds already done no more work to do.
Being addicted to rocks does crazy things to your mind... and wallet.Alex,
was looking for something I read in your build thread and came across this prophetic conversation...LOL!
LOL, he's not even halfway down the rabbit hole.Alex,
I'm confused, they work in the off position? my Markers are 2 wire but I think 01 they are different for some reason.I'm going to replace them with 3 wire button lights and put them in the same area as @DrDmoney. The stock 2 wire they sent only works with the headlights on or off, not both.
yup, were still waiting for dynatrac 80s, 20" travel coils and a 454 big block swapLOL, he's not even halfway down the rabbit hole.![]()
so much more to accomplish.yup, were still waiting for dynatrac 80s, 20" travel coils and a 454 big block swap![]()
and here im thinking about outboarding but have no idea how... then theres thisso much more to accomplish.![]()
I have 3 wire to work with. Don't quote me on the colors since I'm going off memory but the jeep has Black-purple, grey, a blue.I'm confused, they work in the off position? my Markers are 2 wire but I think 01 they are different for some reason.
I'd be happy to walk you through it one day. If I recall correctly though you have short arms so you'd need to fab up a new rear TB mount. @Nickgsjeep would be a great jeep to reference.and here im thinking about outboarding but have no idea how... then theres this
Hats off to you alex, this rig is a beast!
I would outboard when I spurge to the midarmI'd be happy to walk you through it one day. If I recall correctly though you have short arms so you'd need to fab up a new rear TB mount. @Nickgsjeep would be a great jeep to reference.
After all the cutting, grinding, and welding of the midarm the outboard isn't that intimidating anymore.I would outboard when I spurge to the midarm![]()
LOL. we're all going to the same place, just arriving at different times.I would outboard when I spurge to the midarm
I definitely foresee it in my future
^^This^^After all the cutting, grinding, and welding of the midarm the outboard isn't that intimidating anymore.
I've been daydreaming lately of cutting the rear section of my frame off and doing the BCE.
