what is the formula for estimating caster from pinion angle?. sitting with front axle on stands just over operating height, my DS angle and pinion angle are virtually equal. I ordered the spacers to fill in that lower front control arm bracket. When I get them installed, I will set it down and recheck angles. I am trying to wish that pinion up a half degree. I do not want to shorten my lowers.6* should be about right for your setup me thinks. The calculation for my LP30 is spot on with the alignment specs. It was tough handing over $80 to get a printout, but I did it. Guessing it costs even more for you city folk. Everything over there costs more as I found out over the weekend.
Like jjvw said the correct way to do it isn't using a formula. You would want to let the suspension hang at full droop and keep adjusting down until start to feel it bind. Then push it back up a bit. If your getting vibs then keep adjusting up until they go away.what is the formula for estimating caster from pinion angle?
I think I am very close to 5. But, so is my drive shaft. I am not on my tires yet. My jeep had lost the cams at some point in the past. I am going to get that space filled up before I set it down and get final measurements and a test run. when I get it smooth we will see how the formula works on mine. Thanks.Printout on my caster was 4.5* driver, 4.7* passenger. Would like 5*.
Relocated the arb air chuck up to the front bumper. I bent a 2" flat bar to make the mount. No more opening the hood to fill up for me!!!View attachment 86083View attachment 86084
Good thinking.You'll need a cap on there to keep debris out!
We are still figuring out the capabilities. Maybe I'll flat-tow it to the next outing.Any mods planned for that bad boy?
We are still figuring out the capabilities. Maybe I'll trailer it to the next outing.
I'll need to add a brake controller to the jeep.
