The forum won’t let me upload a video. I will have to try from a device that’s not my phone.
Ok, I'll road test it when I get it home from work tomorrow and see how 2nd and 3rd are. Valve body would be "good", because I can pull and mess with that without removing the transmission from the Jeep. I did check fluid level running in neutral, but it might not have been hot enough. I will check again tomorrow when I road test it. Full capacity should be 9ish quarts because of the deep pan, and I think I'm about there, but it might not be full enough.If you have no issue in forward gears thus far I would road test it and get it to 3rd and test the lockup. If you have 3rd that will tell us some things.
If you air checked it then you’re probably ok there. Plus manual 1 uses the L/R band too, so I’m feeling valve body. Internet is out in the neighborhood so I can’t pull up the FSM to check what valves work in reverse.
You checked the fluid level running, at temp, in neutral?
It’s not that sensitive to the level, despite what a certain former member would lead you to believe, if you’ve run across his formulaic posts. But it’s easy to be well short right after a rebuild. There’s lots of places for it to fill up. It’s like a mechanical sponge.
When you bolted down the pump, did you have any trouble rotating the input shaft afterward? That’s another last minute check I do, sometimes it won’t seat just right, and you’ll know cuz the shaft will be impossible to turn. I doubt that’s an issue, again, just collecting data here.
If the pump wasn't seated correctly, could that cause problems with the direct clutch drum that would translate to the no reverse I'm getting? That seems to make sense.
How easy is the input shaft supposed to be to turn? I could turn it, but not very easily, although that probably had a lot to do with it and my gloves being slippery from ATF.
I don't know that it's actually a seating problem, more of a clearance problem, like maybe that fiber thrust washer falls out. It's usually accompanied by the pump REALLY not wanting to drop home. I really doubt that's related. But if you don't have 3rd gear then it won't matter because we're probably taking it apart anyway.
I wish I could just be there and put my hands on it.
I wouldn't say it's easy, but usually i can grab it with a paper towel and turn it without spraining my elbow. It doesn't just spin like a tire when the jeep is jacked up...more like if you've ever jacked up the car and tried to spin the wheels by turning the driveshaft by hand. If that makes any sense.
