Apparently so since you forgot at least a comma and a period.If that is my yoke I am very concerned
Well, it scared the f’.!?,k out of me.Apparently so since you forgot at least a comma and a period.
You aren't as scared as I am.Well, it scared the f’.!?,k out of me.
Oh, I don't know about all of that. I can take a volley ball and wrap it up to look exactly like a Priority Mail package, do I need any more talent?
About time.
Did some planning today on where I’m going to fit everything. The work involved for high lines is a gift that keeps giving! You can see my washer bottle tucked in the back, evap canister, then the PSC reservoir will be mounted through the bottom of the inner fender and to the side of the canister bracket. The G2 mini compressor has a nice feature that lets it tilt on its mount, so that will be mounted to the angled side of the fender. View attachment 300417
The one change to the harness I’m going to make is adding a relay and using the battery to power the compressor instead of just tapping another switched source. It surprises me that the compressor doesn’t already make use of a relay. I suppose most people tap the cigarette lighter or rear wipers or something like that, but I already used those for my seat heaters. Instead I will power the switch by tapping into a nearby switched power (trans temperature gauge in my case), which will then turn on the relay and power the compressor through the battery.
And maybe an apron.
Package on the way. Wear Safety Glasses and gloves.
I’ll let you know how it does once I finish wiring. So far the quality of everything seems really niceFirst time I am seeing that compressor .. had no idea G2 sold one. How do you like it?
The PSC install is going to be good for where you go with your jeep Just make sure to watch out for hikers next time when you go wheeling
I can’t tell if you’re kidding, but I definitely don’t want to find out the hard way that you’re not.
Unboxing will happen Monday night when I get back from my track meet in Florida. I’ll videoPlease Livestream opening this...
We had concerns so we drilled a hole in it. Then it started expanding more and making creaky crunchy noises so we dropped the drill and walked away very quickly to observe from a safe distance.I can’t tell if you’re kidding, but I definitely don’t want to find out the hard way that you’re not.
Now I'm scared.Unboxing will happen Monday night when I get back from my track meet in Florida. I’ll video
