For this project I’m barely welding on the tube. Most of the welding will be done to the existing long part of the truss on there and to the spring perch. For the few brackets I did in the rear it wasn’t an issue but I’ll default to people with more experience to answer your question.Is there any concern with warping the housing by welding on it? Do you take measures to prevent that somehow? Always wonder about that when I see people welding on an axle.
Best method is to weld in stitches 1-1.5 inches in one area and then move to different area to do another stitch keeping an eye on how much heat you are putting into the housing. Taking your time is the best defense against both housing issues and bracket warping as well.Is there any concern with warping the housing by welding on it? Do you take measures to prevent that somehow? Always wonder about that when I see people welding on an axle.
Cool. That seems to be what I see most of in automotive. I had a guy who runs an axle shop tell me once that any axle that's been welded on is warped and could benefit from straightening, but he straightens axle housings so it stuck in my head but I never could decide if he was full of it.Best method is to weld in stitches 1-1.5 inches in one area and then move to different area to do another stitch keeping an eye on how much heat you are putting into the housing. Taking your time is the best defense against both housing issues and bracket warping as well.
You may remember when I did the truss on the 14 bolt, I took my time and moved around a lot. I very deliberately took my time knowing that there was a risk of warping (because I had already shraightened it once!) and it still moved enough that I decided to straighten it again.Best method is to weld in stitches 1-1.5 inches in one area and then move to different area to do another stitch keeping an eye on how much heat you are putting into the housing. Taking your time is the best defense against both housing issues and bracket warping as well.
I do. Where we are trying to avoid movement from heat driveline guys use that to straighten shafts.You may remember when I did the truss on the 14 bolt, I took my time and moved around a lot. I very deliberately took my time knowing that there was a risk of warping (because I had already shraightened it once!) and it still moved enough that I decided to straighten it again.
It always amazes me how much even crazy heavy metal moves when you weld it.
If by fab, you mean weld on a larger mount that blaine gave me then yesAre you fabbing a new upper frame mount? Larger for the bigger joint?
Don't forget to rotate it 90deg.If by fab, you mean weld on a larger mount that blaine gave me then yes![]()
It’s a 3 link. The passenger upper is going away.What is being gained here that installing JJ at the axle with all 4 links would fix? I like it. Just curious.
Yes I understand that part. What issue were you having that it is correcting?It’s a 3 link. The passenger upper is going away
Edited original responseYes I understand that part. What issue were you having that it is correcting?
Got it!!!! Was just curious. Am planning on replacing the rubber on the front axle with JJ soon and was curious.Edited original response
I have a JJ tower and the cast mount JJ I can sell you nowGot it!!!! Was just curious. Am planning on replacing the rubber on the front axle with JJ soon and was curious.
