I can wait. Looks great though.Here shortly or now if you want to slot the fins yourself.
I'm happy with the aluminum one I got from you but for future reference is the black anodized version something you're now offering?Here shortly or now if you want to slot the fins yourself.
They are both aluminum. The black one will be available soon.I'm happy with the aluminum one I got from you but for future reference is the black anodized version something you're now offering?
Yes and no. Stock is 3/8" return so you have to swap out the adapter x -6 male when you move to hydro assist with the higher performance pumps and go to -8 return. We have the fittings for both.do these install equally well on stock steering (non hydro assist) systems? Just in the return line between the box and the res, right?
I have a tube/fin derale cooler that I haven't put on because I haven't found a mounting option that I like. I don't know if/when I would get hydro assist but the cooler would be nice, especially if it's in a kit ready to install in a TJ and it's already there if I do go hydro assist someday.
With a slight bit of horsepower, you can break that rod end loose in the body and rotate the cylinder back some to get more clearance between the frame and that 90 degree fitting. I'd encourage you to put it back with 609 Loctite retaining compound if you do that.Show and tell time.
First off, thank you @mrblaine for helping me with this project. Blaine came up with the idea of doing the short arm 3 link and could not have done any of this without him.
Summary of changes:
HP30
- 30 spline USA made superior shafts
- arb air locker
- Barnett cover
- mini skids
- lower outboard shock mounts
- hybrid truss (UCF along the tube, old savvy prototype I think over the diff)
- 3 link. Used same joints as the lowers and made my own link with a friend that has a lathe. Frame side mount used stock location, just fabbed new inboard side and top of the mount.
- relocated breather hose tied to control arm along with arb line
- 7* of caster
PSC steering
- big bore box
- high flow pump
- standard PSC or derale cooler, not sure, that I slotted myself and welded tabs on the vbar to mount
- cylinder assist
- Blaine’s cylinder assist brackets
- Blaine’s 4340 tie rod (so heavy duty it’s unreal)
All I had to do was flip the strut around to fit the upper link and pinion.
View attachment 313377View attachment 313378View attachment 313379
The axle came with outboard lower mounts. These sit much lower than stock mounts. I added washers for now at the top of the shock to space it down as much as I could. The travel is 10.7” on these so I ended at roughly 6” uptravel and 4.7” downtravel. This will work until I outboard and get real shocks. One thing I had to do was flip the brake lines to point up to clear the shock can at full lock. I removed the bar pin for the lower mount and they fit in the poly mounts with a washer on each side as spacers.
My cooler is slightly longer than Blaine’s cooler. I believe I posted pics of my slots earlier.
Here is my best attempt at fitting everything on high line fenders. I think under the hood turned out decent. There’s a lot goin on. PSC reservoir mounts to the side of the canister bracket and through the fender. It’s very solid
View attachment 313387View attachment 313388View attachment 313389View attachment 313390
Here are some pics at full bump.
You can slide a sheet of paper between the link and strut.
Good clearance at the pinion
View attachment 313394not a lot of space between the truss and pan. One of the reasons Blaine’s stuff is so well thought out instead of puking a giant truss on your axle because it’s “beefy as hell”
Right as the shock reaches full compression, this fitting touches the frame. I set my rock jock bunpstops (squishy jounces) up to touch with 7/8” shock shaft showing. Just worked out that way with removing the bottom aluminum spacer. That should give the axle plenty of time to slow down before full bump in the event that I feel like driving aggressively to the mall.
Awesome I never thought of that. Thanks!With a slight bit of horsepower, you can break that rod end loose in the body adn rotate the cylinder back some to get more clearance between the frame and that 90 degree fitting. I'd encourage you to put it back with 609 Loctite retaining compound if you do that.
I installed one on my stock system, in conjunction with a B&M trans cooler. What I didn't do was use the nice curved fittings Blaine showed. He has helped me learn the error of my ways and it will get corrected at some point soon.do these install equally well on stock steering (non hydro assist) systems? Just in the return line between the box and the res, right?
I need to do this when I install my auto transmission... That is turning into one heck of a project!I installed one on my stock system, in conjunction with a B&M trans cooler. What I didn't do was use the nice curved fittings Blaine showed. He has helped me learn the error of my ways and it will get corrected at some point soon.
On the plus side, it has worked flawlessly thus far. FWIW, I now understand why the fin notching is needed!
Show and tell time.
Summary of changes:
HP30
- arb air locker
- Barnett cover
- mini skids
- 7* of caster
PSC steering
- big bore box
- high flow pump
- cylinder assist
Right as the shock reaches full compression, this fitting touches the frame. I set my rock jock bunpstops (squishy jounces) up to touch with 7/8” shock shaft showing. Just worked out that way with removing the bottom aluminum spacer. That should give the axle plenty of time to slow down before full bump in the event that I feel like driving aggressively to the mall. The bunpstops don’t limit articulation at all and don’t even hit under articulation.
What's your experience with the lunchbox lockers in snow? I've been thinking about getting one for my TJ and I do like to wheel in the snow. Aside from steering becoming more of a general suggestion with the addition of a locker/limited slip, is there any other tradeoffs?Nice rig!
If I were you I would get a powertrax lunchbox locker up front ( I know you said selectable, but in AZ, if you’ll never see snow a lunchbox will be great. If you will see snow, forget what I said). Then I’d get light front and rear bumpers (Savvy) and a winch. Then I would drive it for awhile off-road and see how it performs before going further.
Locker and limited slip are totally different animals. On-road a front lunchbox locker in snow has some under steer, especially if you are accelerating while turning and if the rear locker is on.What's your experience with the lunchbox lockers in snow? I've been thinking about getting one for my TJ and I do like to wheel in the snow. Aside from steering becoming more of a general suggestion with the addition of a locker/limited slip, is there any other tradeoffs?
Don't let @JMT see thisI can’t believe I’ve gone so long without hydro assist. It straight up made wheeling more fun.
