My radiator fan turns on immediately even though the jeeps been off all night. Is that normal? I thought it was some thermo-clutch kind of thing?
The fan clutch is filled with a thick fluid that becomes more viscous as it gets hotter. The fan will always spin with the engine, even when cold. And the fan will always be stiff to spin by hand, even when cold.
You've got air in there, these bleed like crap without a little hole in the t-stat.
That may not be the whole cause, but it's definitely not helping.
Maybe it bled itself out? Be worth looking to see if the rad is full after it cools all the way down. Fill the overflow while it's still hot so it can pull in what it needs.
My new mopar clutch does this if that helps confirm anything for you. The will roar out of the garage then a bit down the road. It quiets down still within sight of the house.My radiator fan turns on immediately even though the jeeps been off all night. Is that normal? I thought it was some thermo-clutch kind of thing?
Thank you!My new mopar clutch does this if that helps confirm anything for you. The will roar out of the garage then a bit down the road. It quiets down still within sight of the house.
Yeah pretty dumb lol, the hose is a little long too so I was able to cut it flat and just put it back on luckily!That sucks! At least that housing is easy to get to!
Thank you!
New tstat and temps are back to where they should be. It looks like it runs a few degrees cooler than it was before, whatever. It's the 195* one so I'm sure it's fine
Looks like my old Tstat lasted only 15k miles. I think it was a Napa house brand.
Glad it's all straight! Mine is running around 195 as well checked with torque app. Needle is just before/in front of the 210 on the gauge. This is after a new heater core, thermocure flush, mopar radiator, clutch, waterpump and thermostat for reference.
Really putting the UV in SUV today
Collecting wood so I can make something that I can use to get my hard top on/off by myself. If anyone has done something similar (and freestanding) please share
