You need some Skyjacker Black Max shocks.Has anyone gone from the metal cloak rock sport shocks to the rancho rs5000x? I have the Rock sports with MC’s springs and my jeep honestly rides very rough
Yes, sprung weight is the biggest impact to how your shocks will perform. Tunes take all that into account. So any off the shelf shock won't consider it and be set for a generic setup.Does a heavy roof rack make a difference on shock?
In between the Nitrocharger sport and the RS5000x. Hard top, heavy bumpers, winch + a Garvin adventure rack down the line.
Lot of people love the RS5000x here, but probably shouldering less weight up top.
More sprung weight requires heavier shock damping.Does a heavy roof rack make a difference on shock?
Yes, you'll likely be interested in something that is firmer than a RS5000X (the butt-ometer reveals all). I love my Rancho's, but my rig weighs 4,000 lbs topless and 4,115 with hardtop.Does a heavy roof rack make a difference on shock?
I took 5100s off my new to me TJUR and replaced with Rancho 5000x. Less harsh for sure but your results may vary.I have the Bilstein 5100's on my TJ with a terraflex 8 arm. And let me tell you. They ride rough. I feel every bump in the road. It is a shitty ride.
Is this normal?
"If you can tolerate the Bilsteins, that will invalidate any discussion you and I may have from now on.I have the Bilstein 5100's on my TJ with a terraflex 8 arm. And let me tell you. They ride rough. I feel every bump in the road. It is a shitty ride.
Is this normal?
Well I guess I better start shopping around....."If you can tolerate the Bilsteins, that will invalidate any discussion you and I may have from now on.They are quite possibly the most annoying damper I've ever used.
Folks tend to brag about how nicely they eat up the larger events while failing to mention accurately in the same breath they are real handy at determining if a quarter is heads or tails simply by passing a tire over it.
Small event harshness is quite annoying to me."
mrblaine.
Rancho 5000x or Skyjacker Blackmax is the go to rec on hereWell I guess I better start shopping around.....
Or for a longer travel rig, Fox RRs. You can have them tuned to get whatever kind of ride you want out of them.Rancho 5000x or Skyjacker Blackmax is the go to rec on here![]()
For the same price as Rancho and Skyjacker?Or for a longer travel rig, Fox RRs. You can have them tuned to get whatever kind of ride you want out of them.
FamilyFunWagon didn't put that requirement on! But on the used market Fox RRs are not as bad.For the same price as Rancho and Skyjacker?I've got $200 burning a hole in my pocket.
I got some barely used (2000 miles) Rancho 9000X adjustable shocks on Craigslist for $80 for all four. I sold them a year later for $300. I've never found an "off the shelf" shock that rides well on and off road. My Zone hydro shocks (discontinued) have rode as good as any. Rancho rs5000x shocks to me are better offroad.FamilyFunWagon didn't put that requirement on! But on the used market Fox RRs are not as bad.
Doubt you can get them new right now anyways.FamilyFunWagon didn't put that requirement on! But on the used market Fox RRs are not as bad.
That's why I went used. Got 11" front (new, never installed) and 12" rears for the price of just the new 12s I had on order for almost a year already.Doubt you can get them new right now anyways.
Have the same. Yes it is.I have the Bilstein 5100's on my TJ with a terraflex 8 arm. And let me tell you. They ride rough. I feel every bump in the road. It is a shitty ride.
Is this normal?
That's normal for the Bilstein 5100 which is known as a stiff/jittery riding shock. Mrblaine opined you should only run that shock if you want to know if the half-dollar you just rolled over was heads or tails.I have the Bilstein 5100's on my TJ with a terraflex 8 arm. And let me tell you. They ride rough. I feel every bump in the road. It is a shitty ride.
Is this normal?
