Reviving an old thread:
@mrblaine
This is the correct way to install the BMB pads in the front, correct?
The double lip side on the bottom?
I am doing the setup first, before putting them into caliper, so want to make sure that I don’t screw up new rotor, knuckle and BMB pads.
You have it correct.
Well dangit I need to check mine. I figured I had a pebble jammed in there or something and had no idea the orientation mattered. I at least know I don't have divots because I fixed those when I installed the pads.
And now I'm second guessing every brake job Ive ever done.
I am just saying that if your front brake package would have a picture or a diagram of how the pad is supposed to sit in the caliper, it would make the life easier for bunch of folks, and would save plenty of folks from having deep divots in their knuckles (from incorrect installs). Seems like common issue with folks installing the front brake pads incorrectly.
a lot of them probably don’t pay attention enough to where they’d even notice the diagram if there was one.
I would say divots will happen regardless of pad orientation. They will happen up until the weld repair for the divots is done which then finally makes the surface hard enough to not wear away from the pads.
Offhand, do you know of a site or link that can detailed info on how to do the divot repair? My welding skills are not phenomenal but maybe I could tackle this.
I would say divots will happen regardless of pad orientation. They will happen up until the weld repair for the divots is done which then finally makes the surface hard enough to not wear away from the pads. I do agree a diagram could be helpful for the folks not paying attention, but then again a lot of them probably don’t pay attention enough to where they’d even notice the diagram if there was one.
Do you know if somebody sells hardened knuckles with welds added in this areas? I can believe how idiotic is the design of brake and knuckle interaction that makes these grooves/divots happen.
Also, is there any way that the fact I ran w/o shims/clips, with just the pads touching the steering knuckle rails made the problem worse?
I am still trying to understand how people run 200K miles on a single knuckle with the pad cutting through it.
Did you consider making and selling some clips like this for front brakes?Key is to wire brush it until it is shiny clean. Turn the heat up, fill the divot and then use a hard grinding disc to reshape the slide. Use a new brake pad to make sure you don't have it too large which will bind up the pad sliding back and forth.
If there would be clips like this, then this entire divot story would not happen to us, right?
Not speaking for Blaine regarding his interest in such a thing, but there's a lot more to it than just the clip. You have to uniformly remove the clip thickness from the knuckle to make room for the clip. The only plug n play solution would be to sell the clips along with knuckles machined for the clip, otherwise the buyer would have to find their own means of modifying their knuckles.
These pads are dead silent when broken in. If they make any noise, that tells us something is out of whack somewhere and we need to find it.
If the pads are oriented correctly and the divot repair has already been done, what would be the next think you checked?
I've got about 10k on mine after 2 years installed (centric calipers and rotors at the same time) and for about a year I've been getting a squeak. It's not constant, it's in and out with each rotation of the wheel, and it's there when I'm NOT braking. I don't know whether to take it apart and check for pebbles or go repeat the break-in procedure but I'll do whichever.
