I already told you I don't give a FUCK about what he (or you) think of my 9.5xp.
I have the same winch in case you missed that part.I already told you I don't give a FUCK about what he (or you) think of my 9.5xp.
The XP is an excellent winch and one of the few I would use if I was not running an 8274.
WOW you guys are waaaaaaaaaaay over my head. I am happy my little Zeon 8S just works whenever I need it
That doesn't look very fun.I'm just a 8274 FAN BOY...... This is my 5th 8274 winch I've had installed on different rigs and of all the different winches I've tried it's my favorite. But yes a 9.5XP would be on my list of other choices.
Taking a winch apart really isn't any different than taking the suspension or engine apart on our Jeeps.
It's just learning how they are put together and then figuring out what modifications can be made to improve them.
The guys running dual motors and stuff are in a whole other class. But getting to watch the winching competitions can be fun. Doing TRIALS off-roading in Europe is WAY different than any type of wheeling here in the USA. I use to compete in the local events when I was stationed in Germany.
And having a electrical system for winching more than 30-60 seconds at a time is important for some of us also. There are some parts here near where I live that if the hill is nasty it's 3 full winch pulls to get to the top. This is when having dual batteries and a high output alternator come in handy. Set your hand throttle at 1800-2000 RPM's and then just winch. Stop pull rope/cable and winch again and do it one more or two more times depending on how much rope/cable your winch holds.
And if you have one or two members without a winch you really get a work out.
This hill is about 2 full winch pulls
You start at the bottom and go as far as you can and then winch the rest of the way.
This is one of the 3 full winch pull hills. A very few make to to the top without having to pull rope/cable.
There is mud, fun can't be hadIt's a LOT of fun actually. This is Memorial Day weekend most years. Enough snow to make it FUN but it's snotty and wet. These same hills in August and September are dry and dusty and you can walk right up them. I personally LIKE them better when they are wet and snotty as it adds a challenge.
These trails are in the Little Naches area. If you want TOUGH trails you go over to the Rimrock area.
At no time during the half-dozen times my TJ was in deep enough mud to notice was it fun for me. Primarily the cleanup afterwards. Our mud has something in it, probably clay, that makes it nearly impervious to even a pressure washer once it has dried. Dried mud is a frigging nightmare for me.
I bet if you set there on a quiet day you can hear the distinct sound of an 8274 echoing through the trees.I'm just a 8274 FAN BOY...... This is my 5th 8274 winch I've had installed on different rigs and of all the different winches I've tried it's my favorite. But yes a 9.5XP would be on my list of other choices.
Marsden GigglepinThat's an entirely different statement than your "off the shelf winch is hard to beat". You actually even know who Marsden is even though you haven't put two and two together yet. He is the UK announcer for KOH who has come over several times to compete. He is a champion in the UK for many of their off road "winching" events. Winching in quotes since they depend more on their high speed winches than they do vehicle capability. So yes, if you showed up to compete against him with my or your 9.5xp, he would seriously giggle at you and maybe even pin your ears back a bit.
added new terminal boots and applied corrosion preventative compound. If you do any wheeling in the wet or live where corrosion is an issue and want your wiring to last I cannot stress the importance of products like NYK77 or Ultra Seal.
I use the Warn ones. PN 2090 is the old number for a single boot and 98273 is the new number for a pack of four.What boots do you use? Mine are toast and was researching options. I'm glad I found your post about Ultra Seal and NYK77.
You have a preferred vendor, I found Gary's Automotive but if you know a better place to throw a few dollars?I use the Warn ones. PN 2090 is the old number for a single boot and 98273 is the new number for a pack of four.
I get them from my local Warn dealer. Ideally any Warn dealer can get them but Montana Jacks usually has them in stock.You have a preferred vendor, I found Gary's Automotive but if you know a better place to throw a few dollars?
Yes it eliminates the snap ring which with hard used or higher HP motors can fail.What's the upgrade on this one? Is it threaded instead of the circlip?
Warn now has the upgraded brake shaft available as a service part. You will need to order the shaft PN 106132 and a brake service kit PN 8409 to get all the hardware to make it work.
