Of course you need to worry. I did say short drive. Your Jeep will bob and sway weirdly. But you'll learn exactly how the shocks effect "ride quality".
Exactly what I expected
This is a genius idea. How dangerous is it? Do I need to worry if I take it around town and down a highway exit?
Not knowledgeable enough to offer any advice or ideas, but this improvement in ride quality with added weight makes me wonder if the shocks are not compressing and rebounding as they should at normal weight. I think overly stiff shocks would follow my logic, but the impact marks on your jounce pad would be caused by shocks that are too soft, not too stiff. Hmm...There was one time on a trip to the coast that the Ranchos on these smaller C load range ATs felt good and it was when the jeep was loaded with TONS of gear so the extra weight made a smoother ride... whether it was the shocks or tires that benefited from the extra weight I'm unsure.
Would that also happen with too soft springs?
@YonderNorthwest Yeah I was shocked by how smooth the ride was with a bunch of extra weight in the back and 2 people up front. Has me thinking that @Jerry Bransford was right that there's something going on here other than tires.
@freedom_in_4low The marks on the jounce pads could simply be from me jacking up the front using a floor jack on the axel tube near the front dif? Maybe? That requires compressing the suspension before it lifts the jeep up. I tend to do that in the front and use the rear dif in the back.
Did you have stock 15" or 16" wheels? What did you end up doing for tires and shocks?
Stock 15" wheels (as in thumbnail). Mine required a general refresh just from having its original 18 year old sagged springs, worn out factory shocks, steering parts etc.
New 0" lift springs and new shocks made the biggest difference initially. I replaced the old G/Y Duratrac tires just because they were seriously hazardous at their age with G/Y Silentrac A/Ts.
Those changes gave me great stability and removed the boat rocking feeling going around corners etc, but I still have some road shocks come through because I haven't been able to change the control arm bushings, sway bar links, body and trans mounts as of yet.
My guess would be to inspect things like control arm bushings and other rubber components to see if they have ever been changed, you might be on the original 23 year old bushings; they could be bound up, or have become cheese and aren't doing their job properly anymore.
Hopefully replacing some of those components will dampen some of the road shocks you are feeling. The rest is probably just the joy of owning a TJ!
It would lower the ride height.
Lifting the axle does not compress the spring much; normally.
Depends upon the spring rate and height. But assuming these are factory original springs your assessment is correct.
Springs do not affect the ride quality. Let's not do this again.
I just don’t think the PO’s going to get THAT much better ride quality. IMHO, some people aren’t Jeep people. Others are and accept that it’s not ever going to drive like a Camry without a ton of $$$$$ and work thrown at it.. I see this guy as a Jeep guy. You’ll live. Maybe a few broken teeth here and there from the chatter.
Toss a few sand bags in the trunk and let it rip!!
